I officially have a new favorite tool- This thing is cool...
I unpacked it and put it all together. Only took about 15 minutes, counting the time it took me to piece together a pigtail adapter so I could plug it in to my outlet.
It DOES have a NEMA L-6 30 plug on it. It is a screwed- on plug, not molded on to the wire, so you can easily remove it and replace it with whatever you need. I happened to have a short section of cord with the plug I needed on the other end, so I just attached an appropriate plug to the end of that.
I temporarily connected the air regulator, just so I could use it. I'll do a better job of installing it later.
Ok, So how does it cut?
Sorry, I was holding the phone and cutting, so not the best.
I cut some 1/8" up, it cuts like butter! I did some straight cuts, and some freehand 'playing'...
I had a couple of scraps around, so I tried a piece of 3/4 round, that was REALLY rusty-
Did OK, Not pretty but it did the job. You can see some of the 1/8" that I had been playing with in the background, including the smiley face
1/2 coil springs were NO problem-
Cut right through.
I am looking forward to trying it out on some thicker plate- I need to cut a table top out of 1/4", I'll be heading to the scrapyard tomorrow to get a piece.
It comes with some extra consumables, too- I'm not sure how fast it goes through them- But you've got enough in the box to get you going.
