willy3486
I am looking at getting a plasma cutter but I know nothing about them. Here is why I was thinking of getting one. I am looking at cutting. maybe something the thickness of an older vehicles panels. At the most the thickness of a saw blade. I have a Milwaukee reciprocating saw to do thicker stuff and angle iron. Mainly I want to be able to cut salvaged metal, for example I have some old heat pump sides I would like to cut so I can patch a bush hog. I can't justify the higher priced ones as I may use it once a month if that, there may be times I use it on a project multiple times.
With that said the last time I really looked at them years ago they were 500 or more. I got to looking at them in the last week or so and I have seen quite a few of them at 200 or less. Last year I made some knives using a saw blade and cut them with a grinder, drill press and hand file, it took a long time. I ran across this one below and I was wondering about it. I am not looking for a professional type , one more for a hobbyist but not junk. But I don't want one that will tear up after a time or two and one that parts can't be found for it. I am also ok with a refurbished one if it is a higher quality but not a huge price tag. I prefer under 200 if possible as no more than I would use it I can't justify more. I have a compressor, 120 volts and 240 volts. It doesn't have to be this one and can be from other places.
Plasma cutter
Plasma cutter
