Plastic Electrical Boxes for rework
MikeF2316
Thornhill, ON
Back when I bought my house 20+ years ago, I bought a few blue plastic electrical boxes like the attached picture. I just used my last one, I can't find them anywhere now. Are they still available or is there some reason I shouldn't have been using them?
reader2580
Minneapolis, MN
They sell those at all the big box stores unless there is something special about it I can't tell from the picture. I bought several of those style in recent months.
Crazyjake8493
Upstate NY
Every hardware and home improvement store around here carries them. Even some local Walmart stores here have a few in stock.
teamextreme
Lakewood, CO
If you can't find those, you must be looking in grocery stores. They're the second most common electrical box sold and are available at EVERY hardware store in the country.
prostreetamx
Las Vegas
I really like those boxes and have used a lot over the years. The only issue I have is they are not Decora friendly since the yoke sits on top of the flange so the plate doesn't fit flush with the wall and good luck with dimmers. I have trimmed the yokes but I found it easier for switches to not use this box. I just side screw a normal box to the stud after I cut off all the outside tabs.
Busted_Knuckles
Northwest Illinois
There is a glass reinforced plastic or fiberglass version I like a little better ( they are tan ), in just that is a little more rigid, and not quite so "fluid" or flexible.
nh_yota
Seacoast New Hampshire
I've used those boxes for years and now I'm finding that they don't work well for newer TR receptacles because of the force required to unplug something. I have some that are pulling out of the wall because the tabs have worked their way through the drywall.
rlitman
Long Island
I like the glass reinforced plastic ones more too. Around here they're blue, but a lighter blue than the plain plastic boxes.
Marctrees
TX/LA border - Toledo Bend
These two SPECIFIC styles, previously seen by myself at Lowes, and numerous other retail outlets, solve many of the complications in the thread above. Marc
https://www.northcoastelectric.com/822561/Product/7010-8
https://www.northcoastelectric.com/839051/Product/9331-ESK
Notice this third style is VERY similar, BUT -- the ears that sit on wall are a little thicker, being plastic and not steel, so can cause plates not snugging up to wall w some devices and some plates.
https://www.northcoastelectric.com/822541/Product/E-16-8
Marctrees
Also, one can use a steel "gangable" box, and these sheet metal ears, sold seperately.
VERY widely available, least in US.
But, the various non steel ones above are much more convenient, but only for "Romex" - NMB cable.
The steel method below is more for like retrofit in older homes using BX "AC" armored cable, etc. Marc
http://inspectapedia.com/electric/Old_Work_Box_Clipss.jpg
rlitman
Long Island
I meant that I don't see plastic boxes in my area anymore . apologies
Being that this is the internet, and we need to come up with the most outlandish explanations possible, I have to ask if you have suddenly gotten colorblind to that shade of blue. Can you read this post?
rlitman
Long Island
VERY widely available, least in US. Marc
If we're talking about gangable boxes, you could also buy an old-work steel box, and use the ears on that. Those have wide clamping plates on the sides. You can transpose one side, and gang it with the shell of another gangable box of the same size to make it wider too.
JRC3
Southwestern OH
Back in when I was 20 (1990) that was all we had. They always worked as they should...Especially in lath and plaster.
From time to time I still use those metal clips to secure an old double or triple plastic box that has worked loose. Usually because it contains an outlet like above a kitchen counter.
Another beauty of what I call a "remodeler's box" (the plastic ones with the screws) is when a customer hasn't picked out specific lighting like in a bathroom. I can leave the wires long and loose and then finish the wall, then come back and cut the box holes once the lighting is chosen.
tab2
Boston
I only see those metal ones with tabs (madison bars) in commercial work here for old working stuff in. Is there a more robust version of the plastic ones for residential? The two corners that don't have the flip up tabs don't sit very tight to the wall and bothers me.
Any tips?
dw1
Ky
and have the metal wings instead of plastic that hold the box in the wall, a much better box IMO.
MikeF2316
Thornhill, ON
Here's my last one. Note in the bottom right a ground screw, which I don't see in the online pictures.
those are called "old work" boxes. I use them all the time. Theyre still made and allowed.
What store did u shop at?
have you tried a electrica supply place?
Only shopped the "big box" stores so far. I wanted to see if they were available in Canada before hitting an electrical supply place. Or to see if there was a good reason to not use them.
I've used this type, but I don't like the fact that the ears don't sit up against the inside of the box, they always spring back a little, and get a little too close to the brass screws for my liking. :shocking:
Thanks for all the replies all!
