Plastic-handled wrench?
Stuey
28m above sea level
Okay, so yesterday I posted about Stanley's new all-in-one wrench over at ToolGuyd (http://toolguyd.com/stanley-twintec-wrench/) , and most reactions were negative.
I have been holding back on making any unfair judgements, but I can't shake the feeling out of my mind that plastic + torque = weakness.
Granted it's made from "composite resin," but in the end the wrench handle is still plastic.
Then again, one of my dead blow mallets has a plastic handle, and it's extremely solid. Fiberglass hammers are also quite resilient.
What do you think?
box
Toms River NJ
I think....
It would make a nice chrismas present for some guy that....
....wears a suit at least 3 times per week
....does not have a tool box (or only has one made of cheap plastic)
....has never changed his own oil
....never pushed a lawn mower
....gets manicures
see where I am going with this?
BOX
Gmonkee
Composite ratchets get positive reveiws all the time.
This is a double ended composite ratchet with adjustable non-removable sockets.
I can't see it being any better or worse than those in the test of breaking point. I also doubt the handle would fold before the ratchet mechanisms blow.
I like gimmick tools too. I would try to use that one.
No gimmick can ever replace the **** ton of real wrenches I'm hoarding, I just like to play with them on minor home projects.
Stuey
28m above sea level
I think....
....gets manicures
BOX
I don't regularly wear a suit, I do have tool boxes, I have never changed my own oil, I have never pushed a lawn mower, I got a manicure once before my wedding. :willy_nil
That's true, I failed to consider composite ratchets. I've never used one - can they handle larger size fasteners without issue?
Typo in the last sentence of the review?
Thanks, fixed! I proofread everything, sometimes multiple times, but still miss a few mistypings here and there.
babewatcher
East
I've been trying to find sets of metric and SAE composite combination wrenches for years-- that don't cost an arm and leg. I have situations all the time where they would come in handy.
helterskelter
There are certain things you should keep to yourself around here...
Gmonkee
Stuey, I've only used an unknown brand (like it matters, they're all the same) 3/8" drive composite ratchet for short while.
It worked well without being amazing in any way. I was working in auto AC at the time so there were no real tests of hard use at all. I was not inspired to go get one of my own from that experience.
There are quite a few GJ testimonials from others though, some work the trades that these would see a true test of time and stress. General consensus of the owners and users says that these are up to the job.
sloppy
Most are just a composite shell over a metal ratchet May be some exceptions but thats how the ones I have used were made. So yes they handle anything a normal ratchet would handle.
Stuey
28m above sea level
That's what I thought, but it's unclear if these have a steel core or not. All I was told is that they're made from "durable composite resin."
Well, at least the handles are sure to be rust-resistant.
KinzeMech
They should call that a Tonka wrench.
I'd get one for my kids to play with.
BK13
PDX, OR
Well, Mr. Manicure, my thoughts are that I probably wouldn't buy a Stanley branded tool anyway, and this one wouldn't change my mind in the slightest.
