Plastic oil drain plugs
AJHD
What tool(s) are you guys using to remove and install plastic oil drain plugs? Any suggestions?
Been out of the automotive repair world for a few years, but apparently this plastic **** is becoming more popular.
Wrench97
Southeastern Pa
The plastic twist in on the Ford pans?
Pliers, be sure to have a spare oring on hand I'm starting to see them seep around 60k
chris142
apple valley,ca
There is a piece of frame or something blocking the one on the f150 at my work. Can't get my fingers up in there so I use plyers.
Fedwrench
Valley of the sun
Are the pans plastic as well?
Yes, hence the need for a plastic drain plug.
the Lisle tool works well but, a small pair of Knipex aligators/cobras does the job as well.
As others mentioned, it's smart to have a spare drain plug available as well. I don't think it needs to be replaced at each service but, they do seep after awhile.
nadogail
Coronado, CA
I am glad neither of my vehicles have plastic drain plugs. The plastic interior trim is bad enough, at 24 tears of age the oldest one is beginning to show it's use.
BlakeTheCarGuy
Roanoke Virginia
Fords I use a mini set of pliers. GM and others with the 3/8 square I use ratchet and extension just make absolutely sure your drain pan is ready on those I learned the hard way when I dumped 8 quarts of oil on the floor because I didn’t realize it would come right out I’m used to cracking them loose then positioning the pan. Talk about being embarrassed in front of your coworkers lol. Never done one on a Volkswagen thank god so I can’t help with that.
uart
Australia
Oh, that's interesting FedWrench. I only work on my own cars, so no experiece with more recent stuff, but just wondering what's the reason for going to plastic sump pans. Is it cost saving or weight saving or some other reason?
A
AJHD
We have new plugs in stock at the shop. I'm assuming they damage easily. I'm not looking forward to working on them.
I also was told some vehicles indeed do have plastic oil plans too. Not sure how I feel about those either.
I saw a plastic drain plug on what I think was a Ford back in mid-2017. But I haven't seen one since.
However I'm going to guess these things are unfortunately more popular on newer vehicles... We'll see after I've been at the new shop for awhile.
2ndGearRubber
Pittsburgh
They're actually pretty nice, as management can't try to pin a stripped drain plug on you, or cheat you out of labor when you replace lubbies **** up. Sure, they leak, and the plugs never get replaced, but it's one of the lesser evils.
redragoon
Greenville SC
I know VW has been running the plastic pans and drain plugs for a while. They get removed with a flat blade screwdriver and cam-lock into position with an o-ring. O-ring should be replaced at each oil change, but they usually only sell it installed on a new drain plug. I can't speak to the longevity of their design since it was a new car and I don't have to work on it anymore.
Our transmissions use a plastic oil pan and drain plug as well. Those use an internal allen/hex socket to drain the fluid. Have not had one leak in testing. Overall, they serve the same purpose as metal for 95% of the population driving on public roads.
Can you break it by driving your Jeep and landing it on a rock? Yes.
Would your metal pan have survived the same hit? Maybe, at least dented.
Does anyone with a new $60k Jeep go anywhere near those trails? Only a few.
ThePostman
Virginia
Ford diesels were using a plastic pan and plug for a while. Then went back to steel for what seemed a year, then it was back to the plastic. We keep those plastic plugs in stock, and replace them every time, otherwise it was guaranteed to seep. Even then, it still might seep. The plastic vws at least you can get new o-rings for them, and I just use a big flat head for those. The fords tend to have a 3/8s square drive. And yes have your catch pan ready, it drains very quickly.
Squankum
Southeast
Can you put a Fumoto valve on a plastic pan?
Fumoto's website says they're aware of this new development. I got this warning on a recent purchase:
"In some cases, this model has a plastic drain plug. We don't currently have a solution for the plastic plugs. "
dscheidt
lighter, doesn't rust, cheaper to make (can be molded as a single operation, metal pans require multiple steps), probably lower material cost, stronger than **** sheet steel they've were made of, less brittle than cast aluminum, they're quietier than metal ones. What's the down side?
Old Man Roger
Palm Coast Florida
Plastic + heat = brittle <<<Downside.
Firebrick43
West central Indiana
oxidize and crack like all plastics will, heat accelerates it.
FredWanaker
NorCal
cause the accountants said that is the way to go. Why spend $3.79 on an oil pan and plug when one can spend $3.69 and save 10 cents a car. Even with warranty claims, they make millions.
dscheidt
Before or after the alluminum one cracks or the steel one rusts? (I had a Land-Rover 2.25 oil pan rust enough to leak, and require repair. It's 3/16" thick; i've seen people use them to lift the whole truck.) Before or after the rest of the car is scrapped?
They've been around for 20 years, including in a bunch of heavy duty applications. The problems I've heard about have been gasket problems, hardly uncommon with metal ones.
Old Man Roger
Palm Coast Florida
Never in my life would I have thought someone would argue that a plastic oil pan is better than steel or aluminum.:wtf:
minke
fly over country
The 6.2L gas engine in my '17 F-350 has a plastic sump (you can tell by the sound when you thump it) and came with a steel plug. The Fumoto valve works fine.
minke
fly over country
Remember the Land Rover motto: If it’s not leaking it’s empty.
petee_c
KW area, Ontario CANADA
Was about to change the oil for the 1st time in my daughter's 2015 VW Golf TSi (1.8L Turbo)... it has the plastic drain plug in it as well... 1st car with plastic drain plug
Is this a replace item? Can I replace the o-ring? Car has about 100K miles on it, she only drove it 5-6K miles in the past 12 months. She's only had it a year.
Amazon has replacements.
do i need to get these? or make a trip to the local VW dealer?
We've had a variety of VAG cars (both gas & diesel) for the past 20 yrs..... all others had metal drain plugs using metal crush washers.
ching0n
My response was more to the plug before I kept reading and found we had plastic oil pans too. Plastic valve covers seem to be doing alright from what I've seen. In my experience, polymers+oil+heat+time+stress/impact hasn't been that great.
Engineers design parts in accordance with the parameters set by others including accountants that run many companies now. Few companies of mass produced products let engineers design whatever they feel like.
We design for a manufacturer warranty period and depending on market for a ~200k km vehicle life. I expect plastic pans are fine but I'll still question novel methods every time. We all remember how CVT's did initially. Like all things, plastics have come a long way but made me question if there wasn't ulterior motive to force customers to get oil change at service center only (though OEMs don't care much to line dealerships pocket as much as their own). It brought me memories of apple products and their resistance to fixing your own but apple owns their service centers unlike auto.
Wrench97
Southeastern Pa
Currently living the dream with Ford's plastic thermostat housing . . . on my third one.
Ford, GM, VAG seem to have the most issues with plastic cooling system components.
Heavy truck engines have used plastic oil pans and valve covers since the late 80's(Series 60 Detroit), since the early 201x's have started down the path of plastic coolant lines, coolant and oil filter housings/caps...................................
Buck_nekid
Northern WV
Ronin got a valve for the plastic plugs.
Squankum
Southeast
Ahh, now I feel better about the price of a Fumoto! :)
