Plastic Welders Laramy 20-300
jthandyman
Hello, I am wondering if anyone has ever used a plastic welder and how the project turned out.
I have a like new older model Laramy 20-300 with extra heating elements and before I buy any welding rods just wondering what to expect.
For those who have never seen one it is a small compressor built in to a tool box with a hose and a soldering type heated head that the plastic welding rods go through.
Any info would be helpful.
:headscrat
Thanks
Harvey Melvin Richards
I have been fabricating clean room and plating equipment for over 10 years. I primarily weld polypropylene and PVC, although occasionally I use polyethylene. I have always used Seeley guns, although occasionally a Horrible Freight gun, which uses parts that are interchangeable with the Seeley. The guns I use are hooked to the main air line and regulated down to 3 or 4 psi.
You don't mention what you are going to be welding. I buy my welding rod in coils, and I always use a speed tip. I fabricate, so I know what my materials are. If you are trying to do repairs, it can be very difficult to determine what the plastic is. The last gun I bought came from eBay and it came with a box of mixed rods. I have no idea what different plastics are in the mix.
J
jthandyman
Harvy,
Thanks for the reply, the unit was to good to pass up, it has several new heating elements with it and appears to have little or no use.
I am not sure what application I could use it for yet.
I am not sure of all the possibilities of plastic welding or when I would have a need to weld plastic that would be pratical.
Thanks
