I'm helping a friend refit his 80 gal DeVilbiss with a newly rebuilt Saylor Beale 705 compressor head. After all refit we'll have it inspected before running to assure proper assembly, wiring, and safety.
He had it serviced last year with tank inspection and motor replacement. Motor is running 230 single phase. He uses it approx 5 to 10 hours a week for pneumatic tools and a small blast cabinet on his blueberry farm.
But the old one lung small DeVilbiss pump remained. As did the ancient pressure switch. So I'm almost starting from scratch.
The SB head is rated to run at 540rpm with 3hp and 845 with 5hp.
I have the appropriate taper loc pulley size fit on the motor.
I wonder if anyone can help me either with a link to a diagram that describes setting up a compressor or can simply describe it here in this thread.
####### I need to purchase the appropriate pressure switch (SB recommends 130 to 175). What switch do I need exactly? Ratings? Why are some pressure switches rated for single or dual stage compressors? What difference could that make where the switch is concerned?
####### Magnetic starter. There are so many types on Ebay and Amazon. How to choose?
####### Manual switch. Isn't this included on most pressure switches? Or are we talking something different? It also appears to be a feature on most magnetic starters I've looked at.
I also need clear instructions as to plumbing the centrifugal unloader valve on the SB as well as other necessary plumbing.
Thanks so much.
Thanks so much.
