Joe Piro
I hate that you have to read all this to help me. I'm just trying to buy screwdriver bits and bit holders that work properly together and also work with my American power tools. Also I'm detail oriented and I want to understand this. All I have to do is figure it out once, then we're good for life.
I remember reading in a GJ post a while back that Japanese (and other Asian) screwdriver bits don't fit American bit holders. I've been trying to figure it out. Are all the short "Insert Bits" with the little notches for detent... are they the same in Asia and the US? For example are all the 1" long (or 25mm long), 1/4" hex bits the same, and measure 8.2mm from the end of the bit to the center of the notches?
(see photo)
And are all the 1" (or 25mm) 5/16" hex bits the same all over the world??? (and measure 10.2mm)(see photo)
If the short "Insert Bits" are the same internationally, then that fixes half my problem.
This is where it gets strange, right? In the Vessel Catalog, the "Power Bits" that have circumferential grooves for ball detents, are in two big sections:
Type A Bits and Type B Bits. I couldn't make sense of it because there were too many exceptions so I called JDV which is an American vendor for Vessel products; and I should add that Larry K. worked really hard to find an answer to my question, providing great customer service, and he emailed me as follows:
"A type bits have a 14mm ball detent, commonly used in Asian markets and on most electric drivers." (He wrote 14, but in the catalog most are actually 13, and some 14's are actually Type B which confused me more!
And he added "B type bits have a 9.5mm ball detent typically found in the US market."
But in the Ko-ken catalog (Japanese for sure) all the 1/4 inch hex "power bits" have the 9.5mm detent (yup... heres a photo).
Did JDV reverse the numbers? or does Ko-ken manufacture for the American market (which I doubt)? ( Also BTW the 9mm and 14mm ball detents vary with different diameter bits. )
Also what is the standard in Europe if I buy Stahlwille or Gedore bits and bit holders? Do they use the 13mm or the 9.5mm standard? I looked in both German catalogs and although they refer to the same DIN 3126 and ISO 1173 specifications are they the same or different than the Japanese bits? (C6 for 1/4" hex), C8 (for 5/16" hex), and E6.3 (for the "power bits" with the grooves for ball detents).
When you buy a bit holder or a ball detent chuck, how do you know which power bits fit ? It may be moot with the magnetic ones but they are less secure.
Mostly this came up because I was about to pull the trigger to buy a Ko-ken Attack Driver. I couldn't decide whether to buy the 3/8" drive or the 1/2" drive. Then I started looking for replacement impact rated bits and here we are !
Thanks for your help.
(see photo)
