Please help a new owner.
troyzstang
Good morning,
Just had a 24x32 post garage installed and need some advice. Built on a slope and now what. Its about a 16" drop . Should i fill in with 2x6 ptw and then fill dirt around the exterior?
As far as the interior. I plan on crusher and then concfete.
Sound about right or is there a better way?
Thanks
Troy.
58Yeoman
Central IL
My shop was built before I bought my place, and it has pressure treated wood beneath the siding on the backside, concrete floors.
Jhoff310
Perrysburg Ohio
I would use pressure treated wood, BUT i would NOT backfill with dirt. I personally would woud dig down a litte deeper than grande and fill with stone, and use stone along the PT. How will you know when to replace the PT if you backfill with dirt?
PugetDude
Superstition Mountains, AZ
I'd use ground contact PT, then compacted crusher run on both sides. Slope the outside quite a ways away from the building, you don't want a steep slope that won't stay in place. Put a couple of inches of dirt on the outside to cover the crushed and allow a bit of vegetation to grow to prevent erosion; no fill dirt inside.
T
troyzstang
Thanks for all the replies guys. I spoke to our local lanscape yard today and he recommended 1" minus for the interior . Still undecided on the exterior area. I have a fews other areas to address first, like running power.
Thanks again
Troy.
rburke65
Canfield, Ohio
Just a suggestion to future builders.....excavate your build site and take the surrounding areas into consideration BEFORE you build.
