Flashesbuck
- Joined
- Jul 5, 2017
- Messages
- 53
I have had a REALLY annoying issue with my furnace for about 5 years now. Sometimes it fails to light. It will fail to light 3 times then toss an error code and turn on the blower.
I believe its the gas valve, because it lights the first burner, but will not pass it to the next 2 burners, then it shuts the valve (as its suppose to).
Its not the flame sense rode, cleaned it, and replaced it. And i have watched it "almost Light"
It only does this every once in a while, Typically at night, about 2am ill wake up, and have to cut the power, to reset it, and it will light just fine. Im sick of fighting it, and want to target the issue.
I believe its the gas valve, because its a different "click" sound when it doesn't light fully.
The issue is, I cannot purchase a direct replacement gas valve.
Its currently a White Rogers 36E24 205.
Is the replacement valve this? 36H33412
Also when I get a newer replacement, is there any "tuning" or changes that need to be made to the valve? As in setting the flow? or are these things set correctly out of the box?
Thank you for any help. I try to do all my own repair work, saves money, and i like learning about these things so i can make repairs at 2AM in the morning, with out getting a strangers involved.
