7th Kahuna
Today was a good day, finally after two months, this morning I was able to re-establish my picture hosting so I can share things again (and my old posts are illustrated again), and then this afternoon this guy followed me home.
I actually contacted the seller about this a week ago and didn't hear back, so I assumed I got to it too late. Then there it was again this morning. SOLD
Usually I am pretty good at puzzling these things out, but this time I am at a loss. Sorry about the picture quality, the sun was going down. Hopefully there is enough detail that someone can identify it. All the labels are gone.
The buffing wheel is 7" and appears larger than the wire wheel. Without having measured I'm going to say that the guard, if original, is for a 6 inch model.
Of course Baldor is one of the most common, but looking online, most Baldors bolt in the 4 corners. I started out trying to identify the stand, but I don't believe it was original to the grinder. I can see that the stand had a metal emblem of it's own at one time. Maybe as I strip the paint I will find additional clues.
The tool rest is just sheet metal but I'm not sure it's original either, though it has enough paint on it to say its been there awhile. The mounting bolt is an allen head however.
Above, you can see the pins that secured the original tag.
I bought it for the stand as much as anything. A year or two ago I bought a Rockwell buffer but the previous owner got an offer on the stand that was too good to pass up apparently. By the time I got there it was gone. Then they seemed a little put off when I wanted to lower the agreed price.
As you can see, the cord was cut. Without a motor tag, I choose not to even try to test it. Good thing, the wires were shorted.
I figured, once I flipped it over, I would know for certain the voltage and the phase. Well I don't, for certain anyhow. It looks like 110 volt single phase. Only one line is switched. But then what is that black component with the three leads?
I was expecting a capacitor.
Closest thing I have found to a date is on the switch. Looks like May 1962, which if I am reading it right and the switch is original, would make the grinder probably 1962 or 1963.
The stand, I don't know. It is actually a little short but I could add some feet. It's got so many layers of paint on it, I suspect it came out of a service station. I've seen stands like this used with an arbor press before but I don't think that is what this is.
So what does anyone think. If not Baldor, then what? Model?
$25
$25
