Please help me design a walk-in wardrobe...
samb
UK
Now this is something my missus keeps asking me to do, it's time I got on with it! I am a capable enough DIYer, but this is not something I have done before, so I would be supremely appreciative of your advice, I can't think of a better forum than GJ for experience on this subject.
I'd like to make a small walk-in wardrobe space in our bedroom, without a door. Kind of a simple partial wall that you walk around and in, hiding the clothing and sectioning the room. I can then hopefully use this wall space internally for hanging/shelving.
Simple is key, but it has to be strong enough to hold the clothes rails, and not fall over! Something like this... (ignore the child like illustration skills.) - which I'd then plaster over. This is an old photo when house was first built, so is a little sterile, but shows the room layout well. It doesn't look like it, but a C24 2x4 timber would have no problem going there and not hitting the door frame)
Would this style be strong enough? Is there a better way to design the inner wall? I thought the horizontal bars might add some rigidity.
Construction: The house is timber, (see build thread if interested) the timber walls are all lined with 12mm OSB behind the 12.5mm plasterboard onto 120/80cm timber studs. You can therefore screw in anywhere, which has been really handy.
HOWEVER, Does this mean that I don't need to find a stud near to my potential wall location? Would it matter that I am going to screw directly into the OSB walls which potentially at its location will be inline with a stud anyway?
This is the construction makeup of the internal walls.
The floor is concrete screed over timber, it holds some air ducts that flow through the house, but not in this part of the floor. I don't think there is anything important under the screed here.
I was going to use concrete screws into the floor and substantial timber construction screws on the right hand wall. I believe the ceiling will not give me too much strength as this is mostly plaster- I'll have to find the studs and screw into this where I can.
The room dimensions are below, I would say the space that I hope to make usable for a walk in wardrobe will be roughly 2.5m deep x 3.1m wide.
Thank you guys!
Frog1956
You need to draw a cross section of what you are proposing to scale. With the sloping side wall I do not think the concept will work. Only place with standing headroom will be side adjacent to proposed partition wall. If you give yourself 30” (750mm) width for walk in access do you actually have the additional 24” (600mm) width 5’6” (1650mm) off the floor necessary for a dress height hanger rod? Might want to consider a center access option in the partition wall with pocket door closure. This would allow his and hers hanging space at opposite ends of the space with and drawers and a dresser top along the lower wall of the center space opposite the entry.
Shiftless
East Bay SFO
I like that idea. The sloping wall complicates things a lot.
samb
UK
Thanks Frog, I like the idea of two zones split centrally, just means I would have to move the radiator across a bit to allow a wall space. Certainly it will be tight, not really a changing space but at the moment it is all together dead space, so I think even as just hanging space tucked away might work for us, as long as clothes can be readily accessed.
CraigStu
Blacksburg, Va
I am not clear at all what the floor plan has to do w/ the picture w/ your add-in wall. Going by the picture only, I prefer the end entrance to the closet. This hides the clothing until you are past the wall w/o the need for a door. I am not sure how the ceiling light lines up w/ the wall position, but have you considered doing a standard height wall like your picture? It's unusual but there really isn't a need to go full height. Make a slightly ornate support new wall to old wall like this. You could do another support mid wall too.
Shiftless
East Bay SFO
Is there no existing conventional closet in that room?
Is there enough room to build a closet with sliding doors against one of your vertical walls, either where your bed headboard and door, is or the wall opposite that? One option If you built it 6 feet tall, there would be open space above to lessen the feeling of losing space in the room.
Or go full height with custom doors and get more storage space on high shelves behind closet doors. That’s what I did with my wife’s 8 foot wide closet in our primary bedroom. There I did 3 doors instead of the usual 2 so that doors wouldn’t be so much in the way when accessing clothes and shoes and purses and all of that.
Hank11
Tennessee
The dresser on the far left leaves. The entire wall where you want a closet becomes a hanging space for clothes with a low dresser underneath. Underneath also partly containing open cubbies for shoes. Pretend its a retail store display. You already have track lighting for the area.
If it must be closed off, think of either a curtain or sliding panels hung from the ceiling.
