Please Help Me Find A Big Grommet
CHuDWah
Kritter Krick, Flaw-duh
I need a rubber grommet 3/4" ID, 3/16" wide groove, and 1-1/4" diameter inside groove - OD (outside groove) and thickness aren't critical. I've looked locally but they don't have one that big. Any ideas where I might get one?
sgtmac
Wilmington ,nc
Look at a place called aircraft spruce. The part number is AN931- whatever size you need. They have a size chart where u can select the proper size.
padroo
Chesterton, In.
You can make one out of a piece of hose any size you want. Cut to length and slit lengthwise and install.
mnoeltne
Grantsville, UT
McMaster Carr. Part # 9307K143
They only had those dimensions in mil spec grommets, so price is a pack of 10 for $19.33.
I didn't see anything at Aircraft Spruce with the exact dimensions that you asked for.
longez
NW Montana
Just went through this with Spruce; they stopped carrying almost all AN931 grommets that weren't 1/16" panel thickness, and didn't want to special order 1/8" panel thickness AN931-** grommets for me. I was pissed, as I've been a Spruce customer since 1980 and have spent at least $50K with them.
Found what I needed at McMaster-Carr :eek:
