Please help me find floating shelf hardware…..
atwnsw
Here is a link to my project: https://imgbb.com/TTr0cRZ
I am cutting the piece of wood into 3 pieces and would like to find the best floating shelf hardware to conceal.
The piece of wood is around 7/8” and 15/16” in thickness.
I went to Rockler and their produce says that it needs to be over an 1 1/8”+ to conceal their hardware.
Rocker Option A
Rocker Option B
Can you make another suggestion for a product that will work?
Weight isn’t a big deal.
Thanks in advance.
jdl25
Modify those, or make your own?
Grind the baseplate smaller. You could weld the holes closed and drill new holes if they are too close to the edges.
Make new ones exactly the size you want?
Keep shopping for some that will work...?
WWheeler
Middleofnowhere USA
If you are ok with doing a little sheetrock work & painting you could cut out the section of sheetrock to install a backing board(s) between the studs to mount the bracket(s) to so that they sit behind the sheetrock with just the tube supports coming through.
rlitman
Long Island
Find a thicker slab, or learn to weld and attach your metal frame directly to the studs. Be prepared to spackle and paint.
There's just not enough thickness there to surface mount something over drywall. The forces involved would be enormous. Even 1-1/8" is tiny for a truly "floating" shelf.
johnre
Portland, OR
Both the Rockler and Lee Valley options don't have a backplate that runs the full width of the shelf - which limits the number of wall studs you can attach to.
Here's one with a full-width backplate; if it were me, I'd use it rather than the others:
WWheeler
Middleofnowhere USA
I wonder if you could just drill 3/8 holes perfectly level 2-1/2" deep directly into the center of a couple studs and turn into those holes a couple 10" long (1/2" diameter) lag bolts to a 3" depth, then cut the hex heads off and use those for your floating shelf mount.
tarbellb
Oregon
This ∆∆∆
Drill as near to level as possible
erroring slight pitch up
then tweak with a tube or box end wrench to get proper angle
Hack off the heads and hope you drilled your wood perfectly
You can add set screws to the underside of the wood for some adjustability
