JimmyTheMonkey
As I have mentioned elsewhere, I am currently living in my first home. My HVAC system is quite old (the A/C compressor is older than me!).
My system has a Space-Guard 2200 air filter. Now known as Aprilaire.
I know nothing about these kinds of filters. I see them referred to as "whole house filters" sometimes around the forum and on the internet. Is there anything different between this kind of filter and a regular furnace filter?
Also, it uses one of those annoying accordion-style pleated filters that you have to put the combs in to keep the thing open. Well, most of the combs are broken and move around a bunch so the filter is not doing the best job that it could. The filter element itself measures 20x25x7.5. Is it best to keep replacing it with the Aprilaire 2200 accordion style filters? I see a few other options:
1) replace with accordion filters at $36
2) replace with this drop in NON-accordion filter from Filtrete: $30 from lowes. http://www.lowes.com/pd_120722-98-D...pl=1¤tURL=?Ntt=filtete+20+25&facetInfo=
3) upgrade to this easier to use new Aprilaire filter system for $41 including filter: http://www.amazon.com/dp/B001GDKHQ2/?tag=atomicindus08-20
What does everyone think? Its hard to find definitive info on this unit and the different options. The Filtrete unit is one of the new electrostatic units that has mixed reviews v. pleated units on GJ but I am not sure if that applies because the Filtrete unit is also pleated.
The new Aprilaire and Filtrete units are also around half the width of the OEM filter, so I am not sure if that means significantly diminished filtration/efficiency.
Please help educate me! What should I be using for optimal filtration and efficiency (the latter is a concern because my A/C system is quite old and I don't want to further tax it).
The new Aprilaire and Filtrete units are also around half the width of the OEM filter, so I am not sure if that means significantly diminished filtration/efficiency.Please help educate me! What should I be using for optimal filtration and efficiency (the latter is a concern because my A/C system is quite old and I don't want to further tax it).
