Please recommend a pipe wrench tool
submariner
Western Australia
Please recommend a pipe wrench tool. I need to undo/tighten several smooth chrome finished pipes & fittings. They're mostly between 1" and 2" diameter.
I have a Hazet 2170 strap wrench and a Baby Boa strap wrench. The Hazet is great for larger pipes and oil filters but does not work well for anything under 2". The Baby Boa wrench is good for loosening lids on jars but fiddly and useless for anything else.
An ideal tool would be the Knipex 81 13 250 pipe wrench but it's designed for much larger pipes. Is there something out there specifically for smaller pipes?
S
submariner
Western Australia
Forgot to mention, I've also read several reviews on the Ridgid strap wrench (the gold standard?) indicating that it's not ideal for smaller pipes.
hautpot
California
Its also like $5 USD for 5 pairs? If you do try them out tell GJ how you like them!
EDIT added USD
ihateminimumwage
I don't know how great it would work with chrome, but I've wrapped the hell out of my Channellock slip-joint pliers with electrical tape so the teeth grip, but won't leave any marks.
OutsideMachinist
Norfolk, VA
media
http://www.amazon.com/Ridgid-31305-8-Inch-8-Inch-Capacity/dp/B0009W9BT0
theoldwizard1
SE MI
"Chromed" plumbing should never be tightened more than hand tight ! Also must chromed brass drain pipes are so thin you can almost crush them with your hands so using any kind of wrench will surely ruin it.
As for the chrome "nuts", I have never had to use more than an arc joint pliers (Channellocks) on any of them.
Ericgst
I'd use a Knipex Pliers Wrench for the fittings, the pipe shouldn't need anything but your hand
jallyn
Fort Wayne, Indiana
+1.
For Chrome fittings use the Knipex PliersWrench. I have a couple sizes. For what you are asking... the 10" size are good for fittings up to 1-3/4" across flats. The 12" size are good for up to 2-3/8" across flats. Part numbers are 8603250 and 8603300 respectively. These are pricey but they will not only do what you are asking, but replace adjustable wrenches with an upgrade, provide a handy way to flatten sheet metal and small parts, tighten rivets, and provide a hand-held vice (for tight gripping during drilling or anything for that matter). I can't recommend them any more highly.
As an adjustable wrench there is no backlash, you can hold on to a fastener in a hard to reach area, and they do ratchet very well which a standard adjustable wrench could only dream of.
