Hey all,
Today I received the final quote from the Metal Building contractors I have been talking with. These guys are top notch and do very good work, I have seen their building before. This quote is for a 40x60 metal building + slab + electrical. Please review the quote and let me know if the price seems decent.
TOTAL COST = $74,800.00
HERE ARE ALL THE DETAILS
Permits:
Cost of permits by owner, contractor to do building drawings. If site plan is required, cost to be added.
Grading:
Cost of grading to be added.
Slab:
Furnish labor and materials to install 40’-0” wide by 60’-0” long,
5” thick concrete slab with fiber mesh, 6 mil poly for vapor barrier. A 12” wide by 16” deep continuous grade beam will be installed around perimeter of slab with two #4 rebars. Footings at main columns will be 3’-6” square by 3’-0” deep. Footings at end wall columns will be 2’-0” square by 2’-0” deep. A 3 ½” metal keykold expansion joint will be installed every 20’-0” across width of slab and down center of slab.
After concrete has been smooth trowel finished, a sealer and curing compound will be applied to the slab. Concrete will be 3,000 P.S.I. at the age of 28 days. *Note: Slab will be thickened for a 2 post lift as required.
Building and Erection:
1. Furnish one pre-engineered metal building, 40’-0” wide by 60’-0” long.
2. 16’-0” eave height.
3. One on twelve roof slope.
4. Bay spacing will be on 30’-0” centers.
5. Wall sheets will be 26 gauge with factory baked on paint with fasteners to match.
6. Roof sheets will be 26 gauge Galvalume screw down with stainless steel cap fasteners with manufacturer’s 20 year guarantee.
7. Gutters, down spouts and trim will be 26 gauge with factory baked on paint.
8. (4) 3’-0” wide by 10’-0” long roof skylights with insulation trim strips.
9. (2) 3070 metal walk doors with lever handle mortise keyed locks and thresholds.
10. (2) 12’-0” wide by 12’-0” high 24 gauge overhead doors.
11. Building to be designed for full 20 pound loading and for 115 M.P.H wind and 2016 International Building Code with three pounds per square foot roof collateral load and five pound per square foot ground snow load.
Insulation:
Roof and walls to have 4” thick fiberglass insulation with reinforced white vinyl backing.
Electrical:
(1) One hundred amp single phase panel and disconnect, (2) GFCI
outlets, (6) 110 volt shop outlets, (2) 3-way switches, (2) emergency exit combos with battery packs, (1) 20 amp car lift, (6) 400 watt hi-bays, (1) 400 watt wall pack on outside of building with photo cell. This is based on tying into existing house panel.
Clean Up:
Clean up all excess materials and haul to an approved land fill.
This does not include any site work, grading, sewer, storm drain, or any interior finish other than electrical. This does not include cost of any permits or site plan if required.
Contractor will furnish “builder’s risk” and “general liability” insurance while building is in construction.
We sell metal buildings that are supplied by an American company, designed
and detailed in America, made from steel manufactured in America and fabricated in American-owned facilities.
Permits:
Grading:
Slab:
Insulation:
Electrical:
Clean Up:
