Pliers; How Many Is Too Many?
LesserSon
PA USA
Don, you posted one pair of these with a bunch of gullwings back in post#8. Are both designs considered GMTK-correct?
For a short time, I was fooled by the grip pattern into thinking they were actually Crescent-production, but despite a resemblance, there are no dots in the grid, they feel heavier, and they have the distinctive “made in USA” forged along the grips.
LesserSon
PA USA
These are the Crescent-mfd pliers that led me to think the flying-V pliers could be Crescent - all checkerdot.
@d42jeep
After looking carefully at your examples, and assuming they are WWII-era, would you judge both the yellow-boxed and the red-boxed pliers correct, or only the red-boxed ones? The difference I see (disregarding the finish) is in the typeface design: the “C” in the red-boxed pliers is circular, while the corresponding “C” in the yellow box has slightly flattened sides.
To be honest, I’ve never really paid attention to the differences in font. I primarily look for cad, dark or plain finishes. In looking at WW2 photos, it‘s really impossible to see that much detail. IMG_4326.pngIMG_4327.pngIMG_4329.png
Why did I think you would have something far more exotic. I have a Cee Tee in the kitchen as well. I wish people would stop walking thru the screen door.
Here are the rest of the pliers in the household tool drawer. Hopefully some a little more exotic.
Top to bottom.
The previously mentioned Cee Tee and Danielson, Utica, Crescent, Herbrand, Kraeuter, Channellock, Diamalloy, Lakeside and Harrold.
Beerhippie
Far NE Oregon
Recent addition to the locking pliers rack:
It was the bullet adjusting nut that caught my attention. The price was worth bringing them home.
The adjusting plunger was sticking towards the tight end of travel, which is why the stem is exposed in the picture above. They've got lots of marks from vise jaws on them, and apparently had been squashed a bit causing the plunger to jam. I was able to get a pry bar into the housing and pry it back into shape and now they work--as well as they can. They barely go tight enough to hold onto a piece of 1/8" steel with the adjuster bottomed out.
Etchase
Hawaii
Top to bottom.
I feel so much better:)
MisterEd
Florida
A couple of Bokers found recently, both marked "U.S."
Pexto
Don, you've really got 10 pairs of pliers in the kitchen drawer?
First, congratulations, you clearly have a very tolerant wife.
Second, I think this means we're slowly closing in on the answer to "How many is too many?" :)
The drawer actually is in the hall closet. Here is a picture of the drawer with all the tools in place.
Posting the household pliers fired me up to check the pliers in the garage. Here is the main plier drawer with pictures of the various brands.
The main plier drawer is too small to hold the largest pliers so the big boys are in a miscellaneous drawer down in the roller. Here is the drawer with the larger pliers removed for their photos.IMG_6634.jpeg
Don, put those Petersons that fit on edge vertically and you can "Stack" them horizontally, and everything is more accessible, and takes less space.
The bigger ones can fit between the welding and sheet metal tongs facing opposite ways.
I do most channellocks that way too.
Ricky Joe
Roanoke, Va.
I don't either!
Electrolysis is my go-to rust removal method. In this case, it'd fizz the paint off too; but I suspect I'd be left with a fairly deeply pitted surface, once all the cRust was removed. When that happens, it can be fun to use files and abrasives to smooth it back out, like I did on the pair of Kraeuter pliers off to the right.
That's not the best example, but I had the photo handy. I recently got a "who made these side cutters?" email from my cousin, who was admiring some Kraeuter cutters he'd inherited. He said, "I've admired this tool that I have here. And it's in really good shape. Almost looks unused. It's still sitting on the table in front of me. Quality is amazing. The tolerances kinda blow mind." I find myself wanting to nurture his appreciation and send some more tools his way. :)
Speaking of tired old pliers, I pulled this pair out of the scrap bin thirty seconds after they'd been tossed in. (Along with a nice little pair of Craftsman "Channellocks" that I set out on the shelf for someone to buy). At first I thought it was weird that they'd used a tubular rivet in the pivot, but then I realized the pin was just missing. Box jointed pliers always seem special and this pair definitely has a hand-forged appearance. It will be fun to replace the pin and forge them back into shape. Poor little pliers.
I have a friend who is a doctor, but a blacksmith on the side, and a damn good one. He told me that box joint pliers are a challenge to make, and that he made ten to get one. He is very discriminating. Yours may very well be a blacksmith reject.
Ricky Joe
Roanoke, Va.
Two of my favorites. Reed and Super Grip Tool Company. Patent date 1-16-99. I haven’t seen Wilkinson referenced yet, but haven’t read the whole post yet. My examples of them are head and shoulders above other makes I have owned.
I've got "compound" slip joints and other Plier-like tools, but the only gear drive I recall this AM are my Fiskars loppers...
username2
Those Super Grip pliers are genius.
You know, after my recent thrift store outings, one thing that surprises me is how few slip-joint pliers even have brand names. Even the obviously older ones mostly-always seem to lack that, and I don't think it's from wear.
Many were mass produced for retail companies to sell under their own brand, and likely paper stickers were used if anything. Too expensive to stamp or forge in. A lot were from kits provided to new car owners. There should be Ford pilers everywhere, but I think I have all of one pair of Ford marked pliers.
I haven’t seen definitive proof that the Vlchek pliers that resemble the Cee Tee pliers are GMTK correct although I don’t why they wouldn’t be. The gullwing pliers have appeared in WW2 literature so I don‘t know how anyone could dispute them. IMG_4378.jpeg
I have seen countless unmarked versions of the gullwings. They probably supplied them to many retailers. IMG_4377.jpegIMG_4379.jpeg
Hard to tell the OEM.
Those are cool. But patents were issued on Tuesdays, and January 16, 1899 - although they don't look quite that old, was a Monday. January 16, 1999 - although they don't look quite that new, was a Saturday.
Could be a foreign patent, though that doesn't seem to match anything else about them.
It could also be a TM date. We have seen several tools where the OEM marked it "PAT.", but the date or in some cases a registration number was in reference to the trademark arm of the US Patent and Trademark Office. Have not looked into that yet.
Are you sure of the marking?
Something is amiss and some quickie research did not resolve it. Nothing else is showing up in a search of GJ or Google Books except the BHM brand name "Super Grip" for rubberized handles on screwdrivers.
If we're talking about the same Wilkinson (made in England), I own a pair, needle nose with cutters, posted here. I agree, they are very well made.
Super Grip had a patent in DATAMP for the geared pliers, dated 6/27/1933, number 1915404. Only patent for Gilbey M Clifton in DATAMP or Google Patents.
Searching, seeing lots of poor reading
1/16/36
1/16/99
1/27/33
1/16/39
1/16/33 (wrenching News debunked this mark)
Applied date was 3/27/1931
Thanks, RTM. Interesting. No example posted on DATAMP and no explanation for the "1-16-99" date on RJ's.
Fill in the top leading edges of the 33 they become 99? Poor writing of Jun becomes Jan? Can't guess on 16 v 27.
Hard to say, can't see $hit from my phone.
...one thing that surprises me is how few slip-joint pliers even have brand names. Even the obviously older ones mostly-always seem to lack that,
That hasn't been my experience at all. Just the opposite. I do leave behind plenty of the ubiquitous unbranded Vlchek from the 30's car kits, and plenty of unbranded Harrold, but 9 out of 10 vintage slip-joints I see are branded with a name or logo. I posted a few here.
Could be all those old ones you found are from Stanley tools kits.
People who are trying to get pliers to rebuild a Stanley "kit" are very frustrated. Turns out no vintage Stanley catalogs carried pliers. So someone was selling them, apparently unbranded ( from someone who found an almost complete kit) to Stanley, Toolbox of The World.
Here and following
username2
I checked out 50 or so pairs with no branding (or words at all). I admit that this isn't much of a nationwide survey of thrift store.
LesserSon
PA USA
@Private Lugnutz @RTM @Ricky Joe
You guys agree though, that those Super Grip Tool Co pliers are represented in the patent drawing for US1915404 right?
Only thing I can think is a renewal date or some subtle improvement.
18Jan1938 was a Tuesday, but DATAMP does not have a pliers patent showing, and I don’t have the will tonight to crank through the Patent Office site with just a date.
Ricky Joe
Roanoke, Va.
An interesting point about those Super Grips is the nut. I always had a tendency to pick up pliers that had a rivet, and to not care about those that had a nut. The nut on these looks pretty pristine, and judging by it, would probably have assumed it was much newer than 1899 era without the date inscription. The “99” is much to clear to be a transliteration of any other numbers. They work well, and have had very little use. Also, the handle configuration lends itself more to being used in one orientation than the other. That makes me think that they have a specific purpose that they were designed for, although they are handy for a multitude of uses.
I was referencing Wilkinson made in England. I’ve got three examples, and they are unsurpassed.
LesserSon
PA USA
Yeah, I'm not questioning your direct experience. I'm just saying that it doesn't scale with mine turning over several slip-joints at 2 to 3 flea markets every week for the past 15 or so years.
But… haven’t you generally been seeking slipjoints bearing brands for which there is documention of government purchase? How deep a mental impression do you really form of tools lacking those brands? I think we both remarked about seeing and dismissing many examples of Harrold slipjoints as probable imports prior to positively connecting the dots to the US manufacturer. NOW when I see their characteristic construction I recognize them, whether they bear the telltale “H” or not, and I tend to remember seeing them. I think there’s a psychological bias to memory that favors things we recognize over things that we do not. When I’m focusing on a single brand, I barely register whether a tool is unbranded or just doesn’t bear the brand I’m seeking. After I walk away, it practically ceases to exist for me unless I see someone else posting about something like it shortly thereafter. The whole “tools turn up in threes” thing seems to me to be driven by similar psychological forces of recognition.
LesserSon
PA USA
Ricky Joe just insisted those pliers are from 1899, so seems unconvinced by the patent drawing that they are from 1933.
LesserSon
PA USA
As RTM and Lugz pointed out, the apparent stamped date 1-16-99 cannot represent an actual US patent date, so I was exploring alternative readings that could.
So, let’s explore other alternates too. Let’s find the history of the Super Grip Tool Co Iowa. If they didn’t exist before 1920 ish, I’m really gonna have doubts about the stamping of the patent date, as the 17 year rule says if it was post 1917, it should not have the patent info.
As that a fair assertion?
LesserSon
PA USA
I’ll say this: Worthpoint has several listed, alternately claiming 1899, 1933, 1938, and 1939. EDIT - eBay had one listed from 1898. And a differnet on-line auction says 1889.
So reading that date has been a problem for others as well.
Some are stamped Jefferson Iowa and Truth.
I think if we could find actual company history, we may learn whether it even existed in 1899.
EDIT - exactly, RTM.
