drivesitfar
Re: ~ Plomb tool picture thread - show your stuff!
Provi: thanks for the link and information. good stuff and has other links in the link to keep me (us) reading for days. :bowdown:
nucklebuster
Fargo ND
Here's the collection as it sits today. 5295 3/8 socket set box has original cardboard box with it. Gentleman bought it, put it away for 50 years, and I got it from his son. Pant flecking in places but an amazing find in my estimation, NOS! My favorite is Big Bertha though, with her 2 extensions and a 2 15/16" socket. The largest 1" extension is stamped "War Finish" which I think is pretty amazing; during the height of WWII that huge chunk of steel was a necessary part of the effort to bring down Hitler and Tojo. My 1/4" ratchet is also a War Finish model.
Out of curiousity (twertsy maybe can comment), has anyone been able to figure out the MFD XXXX USA vs MADE IN XXXX USA. I assume the "MADE IN" is older... :beer: happy hunting all!
twertsy
Reedville, VA
Yes, "Made in" is older. You can get fairly close, and even dead on dating Plomb and Proto from the '20's to 1957, and 1976 to present. The 20 or so years between '57 and '76 are tougher to date, although we're working on that too. You can find the date codes for '76-present here.
twertsy
Reedville, VA
Hey Chop, as far as I'm concerned, those boxes like the one you posted are near impossible to date. Every one I've seen, even those known to have been purchased new in the '40s are all stamped Plomb (round O) Los Angeles. I don't know why but they didn't appear to change the box stamp (except the paper on the inside of the lid) like they did the tools.
chopper1
Member Emeritus
Ohio's North Coast & Florida's West Coast
My guess would be that they had a lot of lids stamped and figured they would use them up rather than scrap them
chopper1
Member Emeritus
Chopper: it looks a bit crowded in that box so maybe you might consider shipping the duplicates to me. :D
one of these days i'll find one of those boxes that isn't $150-$300 in the wild.
If I recall I paid about $15 for my box but it needed a little work.
twertsy
Reedville, VA
Same goes for the 1/2" drive set box. Maybe?
Yup, all mine are round O, never seen a triangle O 1/2" drive box or Tool Box. "Might" have seen the triangle O on 1/4" drive boxes but I'd have to check on that one.
r_olson_06
SD
I know my 1/4 plomb box has the triangles. It is a red hammered style paint.
Sent from my XT1030 using Tapatalk
twertsy
Reedville, VA
Thanks for confirming. I'm not at the shop but I thought I remembered some of my 1/4" boxes had the triangle O.
Rileysan
Milwaukie, Oregon
My meager Plomb collection.
Of note is a WF (Wright Field?) DBE wrench next to the same wrench without the WF, a "War Finish" combo wrench, a 1/2 drive 8-pt socket, and a 3/4 drive impact.
Brian
twertsy
Reedville, VA
Brian
The ones that say "War Finish" on the head are pretty hard to come by. I'd be interested if you ever want to part with it. Yes, WF is Wright Field, often confused with "War Finish." War Finish was commercial market tools whereas WF were military contract.
Carla
MEMBER EMERITUS
This is a wall hanger in the garage. I thought it was a cool tool, I'd just never seen on like it. It's stamped "1AM(1 1/2) PLOMB 2624" and appears to be copper(?). Anyone know anything about it? I've also got some random 3/4" drive sockets and an adjustable wrench at work.
I've a couple of the copper-plated Plomb box wrenches myself, they're not particularly rare. (altho finding enough of them in 'pristine' original condition to make up a 'full set' display would likely be 'collectors' unobtanium' these days, to be sure.)
The coppered wrenches were listed in some older Plomb catalogues, advertised as 'non-sparking'. The Navy bought some very large number of them, presumably for use on fuel pumps and piping systems. Its been quite a few years ago, the now, but I remember seeing tubs of wrenches from decommisioned ships at the Navy surplus sales, with quite a few of the coppered ones in the mix.
The copper plating was not very thick, so some would be found on which the plating had been worn to expose the underlying steel. I'd not be surprised should some advanced Plomb collector put together a set of the 'American Standard' marked heavy pattern box wrenches and send them out for copper-plating, just for display, as there are not very many wrenches in such a set.
cheers
Carla
r_olson_06
SD
I think sometimes with Nickel plated items will show a copper color once the Nickel plating wears off. This is usually seen in early took but I have not heard plomb using this.
r_olson_06
SD
So I have started to put my plomb items on a peg board to more easily see what I am missing and to have them all in 1 spot vs drawer after drawer in the tool box. I have stared with pebble combos but now realize I am going to need alot more peg board hooks.
pistolpete1313
Fort Collins, CO
I don't think I've seen one of these yet, tools were meant to be used and brass hammers just don't last that long. Any info would be greatly appreciated. I did grind down the face where it had mushroomed quite a bit. It's lived a good life, any idea what the backside had on it?
Here are pictures of some war finish sockets I used to own.
twertsy
Reedville, VA
Quite sure those were stamped the same on both sides. I believe that is quite rare.
Here is mine but I can't make out what it says either. The other side is totally obliterated.
twertsy
Reedville, VA
Fellow Plombers, would you mind checking your collections for Plomb Made in U.S.A. marked tools with date codes stamps beginning with 2, 3, or 4? I don't believe they exist.
twertsy
Reedville, VA
Any thoughts on this ratchet? We're thinking it is a Bog/Cragin produced ratchet during WWII. Link
Rileysan
Milwaukie, Oregon
Plomb 1061 DBE (1 1/4 x 1 1/?) - This thing is a monster!
Rileysan
Milwaukie, Oregon
Plomb 15/16 box-end spud wrench. I know nothing about it, but my gut tells me it's rare. Is it rare?
Brian
twertsy
Reedville, VA
Brian
I think someone used that as a tent stake.......and forgot to "pull up stakes." Anything on reverse like "U.S.A.?"
Sent from my SM-P905V using Tapatalk
twertsy
Reedville, VA
I updated the announcement on 2-letter code dating to include what I've found thus far moving on into the Proto LA era. You can read it on the front page at toolarchives.com
twertsy
Reedville, VA
In addition to the above, I'd really be interested in seeing an example of any tool containing a 2-letter code ending in A, D, or E. We've made the assertion that IF a 2-letter coded tool ends in an A, the first letter will always be L. I'd love to be proven wrong!
btrnuthatch
Here are three 1/2" drive sockets I have and two 1/4" drive pieces. Four "A" and a "D"
Oops. Two "letter" not "number letter" code. My bad.
MShaw
York, Pa.
Here's my total supply. A 3/8" drive 3/4" flex socket stamped Plomb Made in USA and a 3/8" Proto stamped Proto MFD in USA
DuroChrome
Oregon
I am an active member of an automotive board and we have an ongoing vintage tool thread. A member of the board sent me this christmas present after seeing my small tool collection. It is the nicest one I have! :thumbup:
drivesitfar
DC: it looks like a smaller 3/8 ratchet or do tell what size it is?
ALL: Zeet
posted a nice picture of some Plvmb wrenches sitting on the lap of a Pin Up girl we all might like. here's another Plvmb ad Private Lugnutz put on that thread that might be the same gal. here's a picture of the gal without the wrenches on her knees without any tools for comparison. BCZ also found a few pictures that might be the same gal Paula Doretti.
no wonder I (we) like Plvmb tools.
DuroChrome
Oregon
It is indeed a 3/8" drive! It has the small cast lettering on the handle, my other plomb ratchets have the larger cast lettering. It has almost all the plating still present and the action is very smooth.
r_olson_06
SD
Isn't that a later generation plomb? I was under the impression that the more round handles were 1940-50 and the related handles were earlier.
DuroChrome
Oregon
I don't know. I'll have to find out.
Edit: I saw this on AA, it looks like it was made between 1945-48.
twertsy
Reedville, VA
The date information on Alloy Artifacts (1945-1948) covers the full production of "pebble texture" Plomb ratchets. These were made in two distinct styles. The earlier version has squared edges to the handles and says "Made In U.S.A.". The later version has rounded edges to the handles and says "MFD. U.S.A." It is difficult to pinpoint the exact day when the change from Made In to MFD occurred, but I would say that the MFD pieces date to 1947-1948.
Here is a link to what we've come up with in terms of dating during and after the war. It's based on hundreds of examples. Rebuttals welcome!
DuroChrome
Oregon
I see what you mean...the handles are quite different!
DuroChrome
Oregon
The Made in USA side. It is definitely more square. I didn't realize one was older than the other. :thumbup:
