sky jumper
- Joined
- Mar 13, 2018
- Messages
- 127
getting ready to run a 100A feeder to my detached garage. House main is 200A and is completely full, so I have to add some kind of disconnect/main lug panel outside to run the feeder to the garage. the run is 125ft. plan is 2" sch 80 pvc 18" deep with 3ga copper feeders.
questions:
1) what type of disconnect/main lug do I need to tap off the meter socket for the garage feeder? I'm going to hire an eletrician to do that part, but I need to buy the parts.
2) do the 3 main 3ga feeders need to have special colors or markings or can they just be black?
3) the ground conductor needs to be 8ga green, correct?
4) will a Squre D QO120M100C work for the subpanel?
5) do I have to switch to RMC where the conduit surfaces to LB into the garage?
6) anything else I'm missing/need?
questions:
of disconnecting the feed and rolling back wiring past the break, cut deeper into the run to glue in new parts, pull wires back in, which might be very bad if some is buried in concrete and that's where the coupling must go.
