Thanks. Any idea how to use the top part with the lightning bolt and sensor?Gap gauge right, gap adjustment bottom and stabbing thing left. Good luck.
Zim
Oh ok. I see now. It's used like how you would put the clamp end on a spark plug wire to check the timing, but you just touch this up to the wire. Thanks.Looks like a neon bulb there to check for spark at the plug wire. Put the sensor up against the plug wire while holding the metal portion in your hand to provide a ground for the neon.
More compact, pen size versions*of this were common long ago when engines had spark plug leads.
I need a gapper this bulky like a hole in the head. Gimmick tool with little to no practical usefulness.
*https://www.ebay.com/itm/3066720260...d=2&mkscid=101&itemid=306672026032&targetid=2
No sure don't. Is that a little light bulb in the middle?Thanks. Any idea how to use the top part with the lightning bolt and sensor?
