Pluggable line voltage thermostat
TomC750
Upstate NY and TN
Is there a line voltage thermostat available I can plug into an outlet and a cube heater into? The problem I have is in my garage bathroom in which I try to maintain about 60*, the differential is way too wide with this heater and a previous one. I guess I could install a thermostat and tie it into an outlet. Just looking for a simple solution.
tailshaft56
Miami Ok
Yes. they sell them for the Salamander type portable heaters. I would check to make sure they rated for enough amps of your cube heater. in a salamander they just run the fan and ignition ckts.
tailshaft56
Miami Ok
I used a salamander in my old shop. I bought 110 volt thermostat connected to a regular outlet rather than the ones made for that application.
T
TomC750
Upstate NY and TN
Thanks tailshaft. Probably won't find one at Lowes or HD though. There is an electrical supply house locally however.
