Plumbing Air In Your Garage???
Aeroman
Hi All, has any one ever tried John Guest's Products for plumbing your airlines from your compressor? I have read about people using copper, black iron, and PVC tubing...I just wasn't sure what route I should go with and being cost effective while maintaining safety.
Thanks....
shocksystems
Ipswich, MA USA
I have a related question. When running this "plumbing" in a new garage construction would people recommend mounting them "in the walls" or hanging them externally with stand-offs?
Cheers!
Jim
Thanks....
NHCharger
New Hampshire
Hey Jim, welcome aboard.
I see you live in Mass. I've been a builder for 20+ years. I would not recommend installing air lines inside the walls.
Two reasons.
1. If you develop a leak say five years down the road how much wall do you take apart to find it?
2. You live in new england. Your going to have very cold air in the outside wall in the winter and with the warm air rushing by in the pipes you are setting yourself you for possible condensation problems in the wall cavity, not to mention the amount of condensation inside the pipes that could damage your tools.
shocksystems
Ipswich, MA USA
Thanks. Your answer makes good sense. As I recall from a garage I worked in with the air lines on stand offs they also made a handy place to hang your drop light :)
Jim M
Two reasons.
dps
I'd say, treat it just like you would other plumbing. You wouldn't run water in an outside wall without special consideration. Inside walls or ceilings, no problem. You don't worry about water pipes developing a leak in 5 years, why worry about an air line? In fact, it's potentially easier than copper plumbing in that you can run a continuous air line if you use either pex or air tubing from Goodyear, Graco, etc. with no internal joins/splices. Now it's safer from accident just like water lines are.
To me though, it would be a matter of appearance and cleaning. If you did a beautiful job with copper all polished and laquered, or iron done in glossy black and made it a design point, that would be one thing. Otherwise, it's just another thing to collect dust, to remember to take care when near/don't lean things against that pipe, etc.
And you can check with engineering types, but I believe that it's very difficult for rubber or pex to condense on the outside, and you DO want it to condense on the inside of the tube/pipe so that it can drain to low points where it is collected by traps/filters instead of running through your tools and condensing there. Higher quality set-ups specifically run the warm air through a refrigerated unit to get the air to condense out its moisture.
