Neura
So I am in the process of plumbing air lines. Material was decided a long time ago and I am cutting and threading black iron pipe.
the space is a 24x22 garage (small space but what I have to work with right now).
3/4" pipe will be used for a main loop. I have a 3/4" hydraulic hose connecting to the supply for the line off of a 5 HP 2 stage 80 gallon compressor. I am add an auto drain that works off the unloader line.
I am installing a up-lift desiccant dryer. It is a cheap one from Princess Auto (same as HF). needs to be a min of 25 feet from compressor. So I am ponder run the pipe down the wall to the front of the garage and mount it there or down that wall and back towards the compress 16 feet for extra cooling before entering the dryer. and then from the dryer into the main loop around the garage.
The dryer uses 1/2" with a 3/8 reducer how much of a loss will I have doing this should I remove the 3/8" reducer and go with a 1/2" whip hose?
I also have a tire machine that has an on-board tank as well that I am going to use as an extra air reservoir. this is located on the other side of the garage. again it has the 3/4 reducer bushings. should these be removed and replaced with a 1/2 whip hose? what about plumbing directly with black pipe into these?
Should the drops coming off of the top of the main loop be 3/4" pipe or 1/2" pipe? I need to reduce it to 1/2" before the filter/regulator combo.
another question is since this is a small space should I regulate each drop or regulate the entire main loop. Not worried about the cost for extra regulators.
changing out the 3/8 air lines on the reels from 50' to 25' foot lines.
I think thats it for the questions at this point.. but may have some more yet.
