sca037
First off, thanks to Luke for this neat forum!
I'm considering my options regarding the plumbing of air lines throughout the garage, and would value some input from my fellow 'junkies'
Currently, I have a flexible line suspended below the ceiling that runs from the compressor (behind some jun, er.....stuff) in the left rear to a 50' coil ceiling-mounted near the post on the right. That allows me to reach all points with air, but I want to make a multi-port system so I'm not reeling lots of hose out all the time. If I plumb a system using hard lines, is it better to surface mount them over the drywall, or is it safe to bury it within the walls and ceiling and terminate the ports at the surface? I would hate to have to fix a problem in a buried system, but wonder what the likelihood of a problem really is down the road?
I've seen both metal and plastic tubing used for this, but what is the best for a personal (probably never over 150psi) garage and why?
Many thanks in advance,
Brian
Brian
I should have take more time to read it. Any way put on an air filter, I believe the one I have is a 5 Micron filter. It is installed along with a moisture filter just before the hose.
