plumbing: compression ferrule puller?
PoorOwner
CA
These are mine, I don't remember the one on the left is a ferrule puller or not.
It's not been opened so I must have just done it with the smaller one, but it looks like it's almost bent already or need another plier to hold the arms.
Is the left side one it any good?
P
PoorOwner
CA
I looked into it further and put some number onto amazon and found this out to be below. It applies pressure to nut to get both off.
LASCO 13-2706 Compression Sleeve Puller Tool 4661, 1, SS​
P
PoorOwner
CA
I thought I would try to install with old ferrule first. (Both brasscraft) I might pull it if it's not overly deformed.
P
PoorOwner
CA
I've seldom had trouble re connecting a compression ferrule to a fitting. it should seal alright if the original wasn't tightened to all get out
Do you put tape or dope on the threads? I know that's not correct type of threads but some people seem to do this as if that is a principle.
grissom
I have a angle stop with compression fitting on a copper pipe that I just recently discovered was leaking.
Is it best to just replace the whole assembly?
P
PoorOwner
CA
If it is leaking from valve turning (stem) then you can give it a try not to pull the ferrule. I checked what the plumber did on my toilet replacement, I handed him the valve, I think that's still the old nut on there.
P
PoorOwner
CA
You guys want to see how this was converted to 1/4 plastic line?
I bought a valve with 1/4" compression out, surprisingly this isn't a stocked item at the store and needed to be shipped.
Later in the day, I removed this valve, It is close to the wall so I cannot inspect the ferrule, the nut was in the way.
With just the new valve it leaks. I went and use the puller and removed the ferrule (not really a choice at this point)
The copper is pretty crimped but not completely, it has two marks where the old ferrule grabbed. I moved the ferrule a bit out from the old one, a bit of dope, needed all belt and suspender approach and will see what happens.
I may need a plumber to sweat a new stub.
So this kind of thing could be a 5 minute job or a big job.
grissom
This is why I don't really like plumbing...
Expecting it to take 5 minutes if nothing goes wrong but could end up being a half day project
jhelrey
MN
Reuse the nut and ferrule. Coat the ferrule in Tru Blu. No leaks!
PS: When I worked in apartments back in the day, we NEVER used a new nut and ferrule, nor cut the copper line. You'd have nothing left otherwise afters years and years.
P
PoorOwner
CA
I would say have the puller at hand.
If you have a long stub from the wall it is worth a shot, If you need to pull the ferrule cut off one ferrule's width of copper, pipe, then the new valve has fresh copper to compress to. I used a 15/16" SAE wrench to tighten, it's a long one.
