Plumbing help - bad planning on demand water heater
inphx
Phoenix/Scottsdale AZ
I want to complete this hookup this weekend. I hope with stuff I can buy at home depot or lowes. There is about 6" diagonal to make that 90 degree bend with 3/4" FIP connectors.
I mangled the flex copper water heater lines trying to make it work, and then i bought a pair of the longer stainless steel sleved flex but it cant make the loop and connect.
Any ideas?
redneckcharlie
Your local Depot should stock the corrugated stainless supply lines. They are easier to work with then the copper. Get a rough estimate on length with a tape and get whats close. Slightly longer with a bend isnt an issue to get it right. If you dont want to go that route use pex and some female adapters. Youll have to buy the crimping tool. 45$ish for the stainless style clamp crimp tool.
Dumber than lumber
I would go to the industrial hose supply place and have them make me one to fit. Of course they may not be open on Saturday. But they can swage the ends on the hose while you wait. And they probably have weird angle fitting/connectors that would help.
QWIKWHIP
Gansevoort, NY
I would definitely use pex, cut it to the right lengths and make it look nice. If you don't want to buy the crimp tool you can use shark bite fittings, however in the end you'll probably spend less to just buy the crimp tool and do it right. They do have their purpose, but I'm not a big fan of shark bite fittings.....
Sent from my SM-G970U1 using Tapatalk
finn
The UP, God's country
Two short lengths of Pex and a brass 90 degree fitting. Buy the tool and a cutter, and you’ll be done in fifteen minutes if you have never done pex before.
BigGarage
Just south of Detroit, MI.
Any ideas?
If possible you could raise the heater higher up the wall.
Dennis
K'ledgeBldr
Johns Creek, GA
Change the copper fitting you're trying to connect to with an elbow facing to the right (in the picture). The SS flex will do a 180*.
scottydosnntkno
If you go with PEX, keep in mind it has to be a minimum of 18" from the water heater connection.
Tommy
Depends on the code your under.
MI residential installs let us do it right off the tank or tankless output.
Pex is designed for 200 degrees, and to pass any residential inspection your heater has to be set to no higher than 120 degrees
LS6 Tommy
Northern NJ
They can't. No local code can supersede National code.
"UPC Code 604.11.2 Water Heater Connections. PEX tubing shall not be installed within the first eighteen (18) inches (457 mm) of piping connected to a water heater."
There is no code that calls for a max of 120° F, either.
Tommy
sixty4
CT
2 3/4" female adapters and one elbow. Or one coupling and one elbow and a female adapter.
KEH
It is worthwhile to make quality repairs of washing machine water connections. Ask me how I know!. I have had hoses supplied by the factory with the machine fail. I replaced them with stainless steel braided flexible hoses. I think just judging by the op's pics that the braided hoses would flex enough to easily fit in place. If I am wrong, refer to post 17.
KEH
acer66
Western North Carolina
Tommy
Here in WNC they let you run pex right up to the water heater.
redneckcharlie
Tommy
That is completely incorrect. There are many municipalities that have codes on the books that are not part of National codes. It is up to state and local on what and what they do not want to enforce.
K'ledgeBldr
Johns Creek, GA
I would assume that the OP is building a garage which would most likely fall under IRC.
Any state, or municipality, can accept or refuse any code of the IRC. The one thing they can't do is make a code less stringent/weaker than it's written command. Which is to say, they can make it stronger/more stringent.
UPC and IBC usually fall under commercial/institutional/industrial buildings.
LS6 Tommy
Northern NJ
AFAIK, none of them can be less stringent than the national code. I could be wrong. I have been before. If I am, no biggie to me. I just learn something new. :thumbup:
Tommy
blkhonda1991
Connecticut
Tommy
it can be either more stringent or less stringent than the code they adopt, they amend as they see fit per state when it comes to the IRC/IBC codes.
