Plumbing Help. Copper to Hydraulic
E
EB.Bldr
Mid-MO
OOPs wrong picture that's my wife at Halloween. I clicked on the wrong picture. Here's mine. Don't mind the air cooler (don't flame me it's going bye bye)
That's a made up line from a truck place. I used to work in the parts dept.
I need to ask why your doing away with the 'cooler' on your setup?
I am planning on running mine up the wall in the basement using 45's - or 4 switchbacks, then out to the garage. With what has been suggested it will fall short on length at only 20 ish feet. I figured It will be better than nothing since this compressor can only handle 5 CFM on a good day.
E
EB.Bldr
Mid-MO
Ok found a thread...on one of my other actually...that addressed reducing the threads vs drilling and tapping. Here:Link
And found that -12 is a 3/4" equivalent.
NOZZLEMAN
San Antonio, TX
Go to a NAPA and have a hydraulic hose made with a 1/2" NPT fixed on one end and a 1/2" NPT swivel on the other end. Install the fixed end first on the compressor then the male swivel into your system plumbing.
It's overkill but go big or stay home
E
EB.Bldr
Mid-MO
Thanks I plan on talking with them tommorow. Figured up the necessary -AN fittings and it was $75, including the hose (3Ft Minimum). Pretty sure fittings and a hose from napa will beat that depending on what I find out at ACE for fittings.
akdiesel
Wasilla, AK
Dave,
Most of your fittings are in measurements of 16's.
Did you do the work on installing a Cummins in your Ford?
E
EB.Bldr
Mid-MO
Thanks to everyone for the better understanding on fittings etc. I think this will work. :thumbup:
ddawg16
S. California
I'm a little late in the game....
But....I just used a short hose from HF.....my compressor is installed in a 'closset' behind my garage....I have a quick connect in the wall....the short hose has male fittings on both ends....plugs in.
All of it standard 1/4" NPT stuff.....
