Plumbing - over-securing pex?
garrett1812
Indiana
I am going to add a water softener and whole house water filter soon. I plan to build a three way bypass each for the filter and water softener. The entire house is plumbed in pex, so I plan to continue this way. I planned to mount everything to a board, which I will attach with tapcons to the basement wall behind the water softener. I see some ball valves with ear drops, would these be okay to use, or would this cause problems with expansion and contraction by over-securing everything to this board?
http://www.pexuniverse.com/3-4-pex-brass-ball-valve-drop-ear-lead-free
Rookie2
Western Pa.
I don't see any problem with them. I would try to keep all the fittings aligned (use or make stand offs) so that there is no side pressure on the joints (crimp connections).
G
garrett1812
Indiana
Quick sketch of what is planned to mount onto this board.
TLCObsession
Bellingham, WA
You don't need the ball valves on either side of the whole house filter - you buy them with a bypass valve. I would use Unistrut and Hydra-zorb clamps.
My son mounted part of his pex to a board and to a cement block wall. He used Read Head Poly Set fasteners to fasten the board to the wall.
larry_g
oregon
My water softener came with the bypass system built in, making the bypass system I built redundant. Check out the WS before you build your system.
lg
no neat sigline
