In My Garage
For those more experienced than I am, I am looking for the part number for the following item.
I have a main water line shut-off valve on each side of my city's water meter with a 3/4 inch copper pipe. The valves are coming up on 28 years old and I shut them off when going on vacation, especially in the winter should the furnace break down. It is time to replace the cartridges or to at least clean them up for smoother action and to replace the seals.
I am looking for cartridges to save time instead of replacing the bibb washer and O-ring on the shaft. The city needs to replace my water meter after 25 years and the first inlet valve can leak past the O-ring at times, so I am asking them to shut the main valve off. And to save time when the city replaces my water meter, I'd like to replace the cartridge instead of cleaning up the valve and replacing seals.
I got one of these at the local plumbing supply, but it is likely for taps with a 1/2 inch line as the bibb washer is small. An EMCO 1057.
The difference in bibb washers. Left: 3/8" bibb washer on the EMCO 1057. Right: 5/8" bibb washer on my EMCO 3/4" shut-off valve.
My EMCO used with the 3/4 inch line has a much larger bibb washer and backing plate (the rest of it is the same as the EMCO 1057). I've already refurbished the second shut-off valve with a new bibb washer, O-ring and plenty of silicone grease (keeps my valves running forever).
So now I am looking for the EMCO PART NUMBER for the above "original" valve because the EMCO 1057 cannot take a 5/8" bibb washer.
