moobeast2
I just installed a new water softener, pressure booster pump and cistern in my basement. We have a well located a long ways from our house and pressure and flow have always been mediocre. So I put a 100 gallon tank in the basement to fill from the well (with a float valve), then used that to supply pressure booster pump (Grundfos 1 HP). Problem is, there is no discernible increase in either pressure or flow.
I'm wondering if the softener or whole house filter is the problem. The order of equipment is: water tank --> pump -->filter -->softener --> house lines. Should I try running the water through the filter and softener before it goes into the tank?
The pump itself seems to be ok; it pumped lots of water before I hooked it up to the rest of system.
FYI: there is also a filter on line in pump house; I added another in case anything falls into cistern tank.
Appreciate any comments; gotta go back to work!
