Plumbing question
WTXTundra
Odessa
So this water heater was installed about a year ago and the relief valve is starting to look like this. I didn’t have any leaks when I installed it. Any suggestions why the build up is happening?
CraigStu
Blacksburg, Va
I think I'd watch it for a while before taking it apart. My concern would be that you tape and dope it and put it back together and then have a hard time getting it to clock in a good position.
wood02
Evansville, Indiana
My grandfather used "cotton cloth strips" wrapped around" weeping joint and then tied off. This in the day when pipe dope and Teflon tape was not "known" to the general public as it is now. He was born in 1903 and passed in 1984. He knew a lot of "stuff" that worked and probably would be laughed at today. The cotton strip does work...try it and I think you will be surprised.
BrandonV
Arizona
No joke if you have damaged threads I've seen the old wick work wonders.
nadogail
Coronado, CA
When I observed Plumbers working in Spain (1966) they used cotton fibers and oil based paint as Pipe Dope.
rlitman
Long Island
The pressure relief valve is supposed to have it's outlet facing down, and be 6" from the floor, with no threads on the lower end of the pipe (so it can't easily be capped). Is yours facing horizontally, so it directs steam into your face if the system overheats?
I suspect that turning it another 90 degrees tighter may fix your leak.
housewolf
East Texas
I’d probably take it out clean it up, put some pipe dope on it, reinstallI, and check for leaks. Is there a pan under the WH? At the very least pipe the relief valve into the pan. Most places want it going to a drain or safely outdoors. You’ll likely have a mess if it pops off as it is unless it’s outdoors. If it’s outdoors, point it down or put a 90 on it
