OK, I am trying to wrench off this nut that is holding the shower valve's cartridge. The piping is copper and just stands inside the shower.
I have way to hold the valve (visegrip) while I use an adjustable wrench. Though I am afraid I may break the solder joints or copper pipe if I am really going to wrench on it. Just sitting back for now, and trying to do some penetrating oil, descaling. etc
I heard lightly tapping the wrench with hammer might be better than applying huge torque with a wrench.
The nut has 2 flats only.
at this point is it corrosion holding the threads tight? Would CLR free the threads better than vinegar (valve is brass, not sure if CLR will harm it)
If I call a plumber it would be because I am replacing the valve or bath tub all together.
