jtreywallace
- Joined
- Mar 27, 2024
- Messages
- 3
Hi. Planning to build 30x40 and would like to get ideas on how to drain a utility sink and trench drain. I am planning to run drain on outside to tie in down spouts along with a French drain (same trench) to pull water away from building. The sink will be on north wall, trench drain in middle of building, then the downspout/french drains will be outside on South wall. Best way to run these and tie it all in. As for sink, let’s assume this will be not to code and only hot/cold water being used. Thanks
