bfarroo
To me this sounds like a bad idea but I wanted to get your opinions as a group. I'm roughing in the bathroom in my shop and Wisconsin requires a 3 inch main vent stack. I want to keep the stack going up one of the outside walls but the grade beam will be 14x14. If i bring the stack up the side wall it will come up through the grade beam. Is this acceptable? my other option will be to bring it up through an interior wall, across the ceiling and then up the side. This will be a bit more work but not out of the question.
My other question is also related. With the grade beam being 14" thick I'm going to probably want to run the drain pipe under that so the main drain will be 14"+ down. I'd prefer not to have to dig the rest of the drain lines down to the 14". I'm assuming it would be acceptable to drop the sink/shower/toilet drains straight down into the main drain line as this is how it would be done in a 2 story house right?
