I am a new member to this board but so for you have helped me install a heater and a 5hp Ingersoll Rand compressor in my garage. I'm currently working on installing a utility sink. I don't have a lot of plumbing experience so I am looking for guidance. I don't currently have hook-ups but it is an attached garage and it shares a wall with my master bath.
The first picture is the spot where I would like to put the sink (it is just a free standing plastic utility sink from HD). The spot is on the opposite side of the wall from our shower/steam room. There is already a small access panel cut in the drywall - see first pic.
The second pic is in the crawl space directly below the shower. It shows the flexible water lines and the drain pipe. My question is - can I just T into this drain pipe where it is circled in green? That spot is about a 1 1/2 feet below the floor of my shower. It would basically be a vertical drop of drain pipe from the sink to that spot - would it be OK to use a flexible drain pipe? Can I just T - flexible water lines into the hot and cold lines shown in the pic? I know it will rob water from the shower but when the sink is not in use it shouldn't affect the showers performance should it?
Thanks for the input.
