Plywood Direction?
peciam
Hello all,
Building a 26 x 26 garage for my son-in-law. Doing it on the weekends, it's a slow go but we're moving along. Trusses are in place and I'm starting the rake and then we will do the plywood for the roof.
Of course he's very impatient and has a friend that gives advise quite often. I don't claim to know everything and don't tell people they are wrong too often. Here's the question: his friend says it's better to put the plywood vertical up the rafters instead of horizontal. I said as long as we stager the joints it shouldn't matter, but I have always laid them horizontal.
Any thoughts? We're using 1/2 ply with trusses 24" on center and clips in between as well.
Thanks
moserjj
WI, USA
I've always done it horizontal. I like the fact one sheet fastened to more rafters seems more stable. I have done vertical for wall sheeting but I wouldn't do that again
Gary S
Bismarck, ND
I've always been told decking should be installed perpendicular to the trusses.
+1^
I always do it perpendicular to the trusses, and offset each row 4' from the adjacent one. It has been a long time since I used plywood. I prefer OSB. The OSB is marked to go perpendicular to the trusses.
37ford4dr
Arlington Va
will your budget allow for something more substantial then 1/2 ply? thats probably the minimum for code purposes but over time that will get kind of spongy, can you go bigger? at least to 5/8? and yes horizontal
70redbee
Knoxville,Md
1/2" plywood or 7/16" OSB laid horizontal with 4' staggered overlap at ends with plywood clips between truss is the only way to do it right. Anyone to tell you to run it with the truss is totally wrong and an idiot.
rsanter
visalia ca
You want the panel to bridge as many trusses as posable to get the maximum shear strength of the panel and structure
So...horizontal....the way we always see it done
Bob
rlitman
Long Island
Bob
^^^^^ THIS
And yes, 1/2" gets soft. 5/8" is much better, especially over a 24" span.
Or go with 3/4", and forget the clips altogether.
Big-Foot
Midlothian, TX
Ditto on the 5/8 or 3/4"
I put them Horizontal and staggered by at least one truss.. Never have 4 corners meet.
Also in heavy snow weight states, I would consider sistering the top of those trusses where two sheets meet as I don't trust the H clips for a lot of snow weight.
6768rogues
Western NY
The face grain on the plywood goes perpendicular to the trusses. In other words, the long side is perpendicular to the trusses. Plywood is stronger in the long direction; manufacturers and most building codes require it to run across the supports. The friend is just plain wrong. You are wise for questioning the suggestion.
Here in western NY (snow country, using 35 lbs. per square foot snow load) it is standard practice to use 2 foot centers for trusses, 1/2" plywood or 7/16 OSB, and clips between the trusses. If the roof maintained leak free and the attic is properly ventilated, it will last for the life of at least 2 good roofs. The practice has not been around long enough to have experience over more than 40 or 50 years.
mbatarga
GA
Exactly - that's why it should be horizontal.
rogsmart
It's the part that's gonna fall in the ocean when
BWS' link
http://www.apawood.org/level_c.cfm?content=pub_tch_libmain
Will give you a homestudy PHD in plywood technology. I'm only partially kidding, the APA technical library is an amazing resource. Every time I go on it I end up reading a bunch of fascinating stuff totally unrelated to why I went there in the first place.
And for what it's worth... Horizontal.
Big Bad Dad
Southwest/ Central Va.
This is correct! I did a small building once and laid the plywood wrong. It was weak that way. :mad:
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Have his friend put on vertical and ask him to walk on it. Then take it off and put it on the right way. I'ma thinkin' his friend just needs to just make beer runs and stay out of construction!!!
