Plywood Finish
fishspike57
Hudson WI
Does anyone have pics of their finished plywood. We put up plywood this week end and now would like to seal it. We like to see the grain of the wood so looking at the different clear sealers.
rwa2004
Western PA
This is exactly what I want to do. White metal ceiling and all. I plan to coat with clear Thompsons water seal made for outdoor use. The one that keeps the wood for aging from sun.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Toolfool
Columbus, Ohio
I used Deft and rolled on 2 coats before installing the plywood.
Selo
Greensboro, NC
I am doing the same thing inside my garage. My ceiling is open tp the peak, but I am going with sanded plywood up 8 feet. Plan to apply water-based polyurethane in satin. I will NOT be sanding between 1st and 2nd coats.
Selo
Marctrees
TX/LA border - Toledo Bend
I highly suggest you make a sample board and see and FEEL the benefits of a quick sanding after the first coat.
You will see it will be Night and Day.
Quick sanding can be done w one new 120 or a bit finer disc per 4/8 sheet on a
random orbit " 5" ? sander.
NO NO NO need for tack rag, just vacuum loose fine white dust off w shop vac and roller recoat.
VERY brief sanding, like 5 minutes per 4x8 sheet.
All you are trying to do is slice off the little hard nibs that are standing erect...
Micro wood fibers "hairs" that are standing up... that get a hard on when reinforced by the finish.
Only thing to be aware of - Many water polyurethane gets very hard like very hard to sand after a short time window.... can most easiest sanded like next day, NOT like couple days after.
I spray regular old school Nitro Lacquer on a regular basis... THAT particular stuff can be easily sanded and recoated at anytime... even years later.
In like all wood finishing, that brief sanding after the "seal" coat makes a HUGE diff.
Marc
CN Spots
NW Mississippi
I'll second Marc's recommendation. You can sand plywood as smooth as glass but after that 1st coat of sealer you can throw a beach towel up on the wall and it will stick to it. Makes it very hard to clean later.
