Well I spent the extra money and went with the 19/32 plywood. I think in the long run it will pay off.
Nice pickup load !!
What did you have to pay for that plywood per sheet in North Carolina ??
Up here it seems like most houses with OSB roof you will be able to see the trusses after about a decade from the house being built. I guess the weight of the snow on 24" centers will make the OSB sag.
I used the radiant barrier osb on the roof of the shop. It was 102* yesterday and I went up in the attic to check it out. With the ridge vent, gable end windows open and the barrier sheeting, it was hot, yes, but tolerable. Otherwise I detest OSB...
I'd never opt for OSB over plywood. Plywood has greater tensile strength, impact resistance, resists de-lamination better and so on. I've seen many pickup beds lined with an un-finished sheet of plywood which held up to hard use for years. Never saw that tried with OSB. Finally; they build boats out of plywood. Try that with OSB and you'll be sitting next to the Titanic.
-Valentine
minor disagreement, but (like plywood) the wood chips/fibers in OSB are actually oriented into opposing layers to make it stronger.
OSB is garbage. You can spin it anyway you want, but it's not a quality alternative building product, rather just waste product masquerading as something else.
Pros: lightweight, cheap and covered in wax.
Negs: flimsy, doesn't hold nails well, disintegrates under wet conditions, small pieces have no strength, not as strong or rigid as ply.
Take 1/2" OSB on a roof, 24" OC, will sag under weight of shingles. See that **** construction everywhere. Just because it's common doesn't mean it's good.
That same 24" OC, would you jump up and down on a roof deck made with OSB or prefer to jump up and down on 1/2" plywood?
I know it's used everywhere, but I wouldn't use it on my house.
Not true at all on strenght. OSB is stronger than plywood and also today is a good product. Plywood no longer is simply because it's so full of voids now. This information comes from my Dad who was a top dog lumber salesman for 42 years and knows more about wood than anyone I've ever known. If he says it, I listen. Only issue with OSB they've never been able to solve is edge swell if it gets wet. When I use the siding I simply wipe the bottom edge with Alex Plus clear and paint it. Never had that issue on my siding.
Old people have problems ajusting to change.
Code here is 5/8" for roof decking, so OSB is no problem.
OSB is rated for longer unprotected exposure than plywood is also.
I doubt you've even ever been on a roof deck.
OSB:
Splinters like crazy.
Blows out with pneumatic fasteners.
Swells like crazy.
Terrible underlayment.
Not as workable as ply (eg, hand plane or a spur bit)
A lot of apples to avocados in this discussion. Hi price OSB properties compared to low end plywood. I hate CDX almost as much as OSB. They're both garbage to a great extent.
