Plywood Walls - Sealing between sheets?
zc15
For those with Plywood walls, what do you use to seal between each sheet edge?
Some kind of caulking or sillicone?
danho
SW Oregon
I would use a latex paintable caulking if you are going to paint the sheets, or a clear if staying natural. Also make sure the ends land on a wall stud, otherwise you will get flex and your seam sealant will fail.
Innovate1
Wife wanted some thin trim on the gaps so used some primed strips from the big box store about 3/16" x 1" wide. Purely cosmetic. and will have to work around them where I put up shelves but there aren't a huge number to work around and a small notch will do it.
dcg9381
Austin, TX
There are strips you can get for hardie-board, typical use is exterior. They do leave a very obvious line.
When I paneled my shop in OSB, I didn't use anything at the edges. Painted with a high quality "1 coat" paint/primer (it takes 2 coats) - it looks fine for "barndo kitchen". I did it this way so I could remove sections of the wall at any time to get back there and deal with wire/plumbing.
mike93lx
Richmond, VA
If you want to air seal, you would need to tape or use some liquid, like caulking. Then you could cover with trim as desired
K'ledgeBldr
Johns Creek, GA
Air seal?
I’d use lattice. Caulk the seam heavy, finish nail/crown staple the lattice over it, clean/wipe off any ooze- done!
Z
zc15
Not a bad idea doing poly as the seal.
I think as long as the poly and kraft facing are side by side ie. paper to poly, it wouldnt create any moisture issues correct?
Masheen365
South GA
I didn’t use anything. All my seams land on a stud. I butted your pretty tight, maybe a 1/16” gap. If I put anything it would be something like Alex Flex, but I don’t think it’s necessary. All of my walls are 2x4 studs, R13 insulation, 7/16” OSB, Tyvek house wrap and cap staples.
mike93lx
Richmond, VA
I bet there are lots of leaks as you have no air sealing in what you mentioned
Leaflessshadetree
Don't ask.
I left a small gap between the sheets. Didn't fill, caulk or even paint any of it. My interior "air seal" is the vapor barrier between the plywood and insulation.
I've been warned that the plywood will warp, swell and otherwise deform and won't be surprised if it happens. It was unheated for the first few years.
K'ledgeBldr
Johns Creek, GA
Not correct.
A double vapor barrier will trap moisture. Now if they were non-faced batts, you’d be Bueno!
Masheen365
South GA
I guess so. I haven’t noticed. Maybe the A/C has to run a minute longer? I figure the A/C will run all summer long anyways, and my winter low only got below freezing for about 2-3 hours at a time this season.
Sumboodie
AK
It's still below zero here!
ducatithunder
Annapolis-ish, MD
I get being on a budget. If your using half sheets you could just use the screw/glue method. It would make the building alot stronger since you won't have the same shear of the 4x8 sheet. The glue on the seams should be enough to air seal. You should also be able to hit a stud. Scrap off what squeezes through. If not just put in a nailer. I did nailers on all my exterior sheathing joints as the extra 2x4 where negligible but made for a stronger wall. I used huber advantech which called for an 1/16" expansion joint between panels. If you planning on insulating prior to hanging the plywood a vapor barrier could be installed. There is also a foam version of glue that is pretty good for air seal and adhesion.
Firstram
In South GA you shouldn't use anything on the interior, that's for the northern folks only!
NUTTSGT
Northern Central Ohio
I wouldn't use plastic/poly sheeting if you already have kraft-faced fiberglass insulation,
Even if you are using half sheets, I'd still try to stagger the seams. Then use painter's caulk to seal any gaps between the sheets.
Z
zc15
Hell, free half sheets of plywood! In this day and age, doesn’t that qualify for a You ****?
Definitely lucky. Only kicker is that the sizing isn't standard, and they were scraps from a sign company so I have to figure out the best way to cut the weird shapes out of them. Think, if somebody cut a rounded corner rectangle on 1/2 the sheet, so the portion where the round corner omits cutting out.
And like I said, not standard sizing. So I'll have to cut them into ~48x38 sizes. and plan on having 2.5 pieces high
