pneumatic HF jack help
^&right
Indiana
Put a HF pneumatic jack on my shop press. I want to run it with a foot pedal to free up both hands. Ordered a foot pedal off Amazon but it is not tapped for 1/4x20 threads so I can put a barb on it and run hose off it. Which also brought up the thought even if it did, is it able to handle the volume of air needed?
Figured a few of you have done this before so I'm asking, what was your foot pedal set up? All I'm seeing online are pedals to sent a pneumatic signal, not to handle a larger volume. Went to TP tools knowing their pedals were made for volume but I don't want to spend $200+ either.
Any help is appreciated.
^&right
Indiana
@ BIIIK I bought the 20 ton jack
@racecouger - that is exactly the pedal I bought! as pictured, it came with the push quick connect fittings. The narrower orifice got me to thinking it would not provide enough volume.
Seeing your set up and recommendation, I'm going to just adapt as you did! Didn't expect anyone to say this worked perfectly, but I'm no engineer. Many thanks for chiming in!!:thumbup:
vwpieces
Hills, PA
I should install a pedal to mine. :rolleyes: But very worthy press upgrade for getting the air/hyd jack. Every time I use mine, I say it's like cheating... I went 20 years of using the press without one.
The air requirements are minimal for the jack. So, even if you did use the push connectors and tubing it would not be an issue. With my hand trigger valve, I find myself trying to go light opening valve when close to hitting the part. Even using the hand pump again to get things right before going harder.
racecougar
Missouri
The foot pedal is as much a game changer as switching to air-over-hyd is. Being able to keep two hands on the part(s) until the ram has made contact is very helpful, and feathering with the pedal is much easier than with the hand valve. I highly recommend it.
