Pneumatic nailer problem...
Jim Dawson
East Alton, IL (near St. Louis)
I have several nailers/staplers that have all worked fine. A couple months ago I tried to use my Craftsman brad nailer and it won"t work, squeeze the trigger and It just lets out an anemic "psst" and nothing more. I just dismissed it as a cheap tool that only worked a few times before telling me that I should have bought a Porter Cable. Fast forward several months and I get out my Porter Cable 1/4" stapler and drive one staple and the next pull of the trigger and I hear the familiar "psst" and nothing.
Does anyone have any clues as to why and how to fix the thing. Or do I just go buy a $15 Harbor Freight nailer and count on replacing it once in awhile?
Thanks,
Jim
My air nailer(s) have a passel of o-rings and a bumper that must be replaced from time to time. I would either take it to a repair shop that specializes in them or try to find a kit that contains all the replaceable parts and DIY. The shop charged me $45 p&l for the overhaul.
gungatim
west mich
you probably just need a new trigger. they are easy to replace. seals wear out over time. it's easier just to replace the whole cartridge than trying to do the O-rings one at a time, I paid $15 for the last one on my Bostich.
Todd.Brock
Cincinnati
I'm sure the PC is nice, but the HF 18 ga Brad nailer is a solid buy. The only thing I couldn't find was a no mar tip.
I would try some oil and make sure nothing is jammed up in the piston. Mine have done that occasionally and taking them apart , cleaning and oiling have fixed it usually. hf always came with an extra piston and some o rings. Did your PC come with a piston you could try swapping out?
wayne55
I've had a Sears stapler and a Porter Cable brad nailer that both had the same problem. Although they were both seldom used, due to age, a plastic bumper or stop in both of them had totally dis-integrated. I got replacement parts and fixed them both. The hardest part was just cleaning out the plastic stuff from inside. The part for the stapler was about $10 and the part for the PC nailer was $18 from Amazon. I just did this to the nailer about a week ago.
rlitman
Long Island
Yep, could be that too. The piston hits a bumper at the bottom of its travel. They can disintegrate over time. I had this happen to a Grex pin nailer of mine (after a LOT of commercial use; so no complaints about longevity there).
Sometimes they just wear out. Sometimes they disintegrate on the shelf as the rubber/plastic dissolves in the lubricating oil.
J
Jim Dawson
A lot to check, thanks. These aren't worn out from use, maybe from a lack of use. I'm going to buy a HF brad nailer today, it might be cheaper thatn fixing these.
I see they have combination 18 ga. nailer/ stapler for $15.99. With the 20% coupon I can't go wrong.
Hawk
Kannapolis, NC
Just remember to drop some oil in it before and after use. Sounds like that might be a large part of the problem.
