Pneumatic Paint Shaker Repair
Richard D
Texas City, between Houston and Galveston
Mine stopped working. Used to be it would go if you gave it a bump with the palm of your hand, but no more. Is there a common problem that causes this? It moves freely when there's no air but stays stuck in the middle of it's travel under pressure.
rlitman
Long Island
Mine has an in-line lubricator, so it gets heavily oiled. When mine failed, it was a broken hose.
There's a short section of flexible hose connecting the inlet to the piston. The vinyl hose in mine was flexing severely with each stroke and eventually cracked. At that point it hissed and shook more slowly, but I ignored it until it stopped shaking entirely when a chunk of hose blew out.
My fix was to use a piece of hose cut out of a coil hose. Instead of using a short section that just bent in the middle, I put in a full loop circle of hose to spread the bending around, and it's been good ever since and no more hissing.
Lightning rod
Toronto , Ontario
in order for the piston to move back and forth, there must be a valve of some sort to reverse the direction of the air flow on the piston.
It's either broken or stuck with debris or something is clogged.
Assuming it's a HF model, inspect the parts against the parts diagram
For example, part 11 on this diagram is may not be functioning correctly.
rlitman
Long Island
New hose didn't do the trick. When I apply air I can still hear a hiss. I have not opened the valve for inspection yet.
The reciprocating piston works just like the one in an air hammer. It's usually easiest to inject a penetrating oil into it to loosen up whatever got stuck in there and see if some airflow clears it up after that.
barks
How did you "break loose" the screw on top of the piston? thanks.
