Pneumatic riveter purchase advice
kirkkw
Leander (Austin) Tx
I need a air riveter of the type like Taylor T-7891N or Chicago Pneumatic CP9882
to install 3/16" rivets in a medium duty commercial application.
I know nothing about riveter guns but have worn out several Jonesway JAT6034 guns.
I don't have $800 for a commercial grade gun at this time. Any one have suggestions for a decent quality tool in the $200 or so price range?
Ken
Cypherian
Delaware
Look for a used Cherry Max gun on eBay be a few hundred . They are used in the aerospace industry I have used them for to production type riveting from 1/8 to 1/4 alum or.steel rivets. Check to.see what head you need to pull your style of rivet.
Cypherian
CobraRed
Astro PR14, must have thousands of steel rivets through this thing.
zkling
Used there are going to be a ton of industrial options.
Mountain air, makes a pretty nice one. A&P friend of mine bought one as he needed it right then right now. Seemed nice for a little over $100. :dunno:
K
kirkkw
Leander (Austin) Tx
Ok great, I will try the PR14. I found one delivered via Ebay for $78.
Part of problem with the other guns I was using is that the pressure had to be turned up to 105-110PSI to fully set the rivet. The PR14 working pressure is 90-120 so that suggests to me it is a better tool than ones rated for only 90psi.
Thanks for the suggestions.
