Pocket for Garage Door?
bad_idea
Pasquotank, NC
I am in the building process of my 30x40x12 garage. I have two 9x9 sectional doors on the front. They have 32" radius tracks that follow the cathedral ceiling, the door is approx 12" from the ceiling. Stick built garage - 2x6 walls w/ scissor trusses on 24" centers. Doors do not have openers - no opener down the center. If I ever do install openers they will be jackshaft openers.
In my last garage I had trouble with grinding dust floating up and settling on the face of the open garage door. I am thinking about building a pocket around the door to keep dust from floating up there and settling on the door. Anyone done something like that? I would like to make the pocket stiff enough to hang a couple overhead lights from it. A bit stumped on how to span a panel 9' and not sag.
larry4406
Northern Virginia
I did this in a commercial project, unfortunately no pictures.
Ours was a very large aluminum and glass sectional door (like at a fire station).
We had a suspended horizontal ceiling with drop in troffers. We had a slit in the ceiling where the door went in and the tracks curved horizontal above the ceiling.
The ceiling suspension was complicated as we had to use Uni-strut to span the bay under where the door would be when retracted.
The door had a commercial jack shaft operator.
bad_idea
Pasquotank, NC
I hadn't considered unistrut. Just looked up the load capacity for a 10' piece of 1 5/8 (standard size) to be ~400 lbs uniformly loaded. Thinking a couple of pieces of unistrut under each door should hold some OSB and I can mount the lights to the unistrut through the OSB.
Open to other ideas as the unistrut cost will add up quickly for two doors.
kbs2244
Why not just pressure wash the doors?
A cheap washer wold work fine.
In NC that should not be much of a problem.
spudley
Northeast Wisconsin
I think he wants to build a pocket that the door slides into that'll have a limited opening and will stop most dust from settling on a horizontal door when open. But if he has that much grinding dust, I think he needs a big *** dust collector. One can always clean the doors, not so easy to clean the lungs.
Kenstone1
shop vac on near any grinding.
I carry anything small enough, outside for grinding.
What you are considering will keep dust off the doors but not off everything else in your garage.
jmo,
LXCam
I like the idea. I'd do it out of tin stud though, nice and lite plus it won't ever change shape on you.
bad_idea
Pasquotank, NC
Pressure washing the door daily gets old (depending on project). Especially when it is 40 degrees out.
Pocket is intended to be 100% sealed except for the opening the door will go in and out of.
I plan on a dust collection/ventilation system. Plan on building a separate room in the garage for hot work with negative ventilation in the room.
I wear a respirator with P100 filters when grinding.
Looking for a 'belt and suspenders' solution here. My last garage was FILLED with grinding dust and the door was orange from rust. I want to avoid that with this place.
bad_idea
Pasquotank, NC
I have not worked with tin studs. I assume you mean sheet metal wall studs like seen in a commercial building? Will they support hanging a ceiling panel with light mounted from them?
Gearheadmb
If you wanted to simplify it, instead of a full pocket you could just do sheeting from the tracks up to the ceiling, and something from the ceiling to the top edge of the door. I would do something flexible like heavy tarp. Or use wood to box the three sides, and just do enough of a strip at the top to reach a little past the top of the door when its open (i hope that makes sense). It seems to me either of those options would give 90% of the protection using 30% of the materials. I do like the idea of putting lights on it. When i open my garage doors it blocks half of my lights.
LXCam
Exactly and yes since your spans are short. A fixture isn't an issue And even if you needed To go longer then 10ft you can go to a heavier stud and or black iron internal stiffners.
