Pointers for pulling 12 gauge wire in existing conduit.
AffableCurmudgeon
Triad Area NC
Hi,
The conduit is 3/4 metric. It has 2 8 gauge and 2 12 gauge conductors.
I would like pull another 2 12 gauge conductors. All copper conductors.
Roughly 100 feet with 3 90 degree conduit turns (not elbows but regular conduit turns).
Any pointers and advice how to approach it? Thanks.
oldwino
Sonoma County California (wine country)
I don't have my code book handy but sounds like adding two more 12's may put you beyond the fill limit per code. You can try running a fish tape through but it won't be easy.
Good reason to ALWAYS run a pull string in conduit when installing new wiring.
mike93lx
Richmond, VA
You also need to consider derating.
Either way, I think that is going to be tight and tough, at best. Especially at that length
Edit: well the sparkies have spoken. Shouldn't be a problem, I guess
Bert_
NW Iowa
Not sure what 3/4 metric conduit is?
Just use one of the existing #12's as a pull wire. Pull in an extra number 12 to replace it.
Two #8's and four #12's is nowhere near the limit for 3/4.
MrSurly
East Texas
If pulling one 12 out (use it to pull three 12s in) proves to be a problem (there can be a kink, twisted with other wires, etc), you can pull ALL of the wire out while pulling a string in their place, then pull all six back in.
mobiledynamics
Gotham City
U boys pulling alone ?
Man, sometimes I feel like it's always got me a 2 man job....one on one end , the other is just giving it a shake whenever you hit a resistance point, etc.
sparky 1971
Central Iowa
This. And maybe put a little pulling lube on it. Use stranded wire, especially if you are by yourself.
Bert_
NW Iowa
Don't even attempt to pull a hundred feet by yourself. This is a two man job.
sparky 1971
Central Iowa
Why? Last Friday I pulled out one #12 using it to pull in a replacement #12 and two #10's. It was about 125'. It only had two 90's, but I had to go through two 1900 boxes. I only had to go back to the wire cart once when a wire jumped off the spool and got wrapped around the axle. I soaped the head and it actually pulled very easy.
sberry
Brethren, Michigan
There was a wire got missed on a job I was on a little while ago. We managed to use a 14/2 to pull thru a wall to pull in another 2 conductor and a new 3 conductor for a 3 way.
Bert_
NW Iowa
Not saying it can't be done. It's just way easier pulling and less likely to burn through the other wires if you have someone feeding.
A
AffableCurmudgeon
Triad Area NC
Thank you all. I meant to say 3/4 EMT, mistyped it and my iPad autocorrected it as Metric.
I never thought about using an existing 12 to pull 3 new 12s. That is a great idea! I will do that and will use lube. I will also have some help on the feeding end while I pull on the other end.
Thanks again.
ddawg16
S. California
Bert is right....especially with the wires in there.
If it was me, I'd disconnect the existing wires....tape a pull string to them and pull the whole mess out.
Give the existing bundle a good inspection...then add the desired wires and pull it back as one bundle.
Still going to be a 2 person job....one pulling and one pushing...and making sure the bundle does not get kinked.
It can be done with one person....but I can assure you, the puller is going to be making 'many' trips back to the start.
When I pulled a bundle of wires from my new panel to the existing part of the house, I had about 18 wires over 80's long....my kids helped. I had my oldest son (12) at the first pull box....I was at the second pull box...son #2 (10) in the attic pulling the string and my 8 year old daughter outside making sure the bundle did not get in a tangle....
sparky 1971
Central Iowa
Don't pull the existing wires out unless you plan on pulling all new in. Those wires will turn into a giant rats nest on the floor. Contrary to popular opinion, it can be done alone. I have no employees and very rarely have help so I am speaking from experience. You do have help so it will be even easier. Just tie on to a wire, soap it up and pull it.
Kevin Essiambre
Ottawa, Ontario, Canada
The wires can be successfully removed and re-installed without turning into a rat's nest...
The trick is not to pile it all on the ground where you are pulling it out. Have someone pull it into a giant loop on the ground behind you. I've done it many times.
Sent from my new phone. Autocorrect may have changed stuff.
Bert_
NW Iowa
This^
Wires can be reused no problem. As said don't throw them in a pile and it's easy.
nadogail
Coronado, CA
IMHO, 1. wire pulling is almost without exception a 2 person job. 2. It is impossible to have too much lubricant.
