Pole barn build mid tn
mcnair06goat
tn
Hey guys I've been lurking on here for long time and u guys have some great shops, ideas, and knowledge on here. I'm hoping in the coming months to build a 30x56x14 pole barn/shop with the intent of using it as a main shop/garage with a 4 post lift and other small garage tools too. May store few cars tractor and pontoon boat if room left. I am in the planing stage right now and have a shell kit quoted with laminated 6x6 posts 8' oc and 4/12 pitch trusses on 8' also right now it looks like with our budget we can get shell kit and few other thing to start the build.
The majority of the build I want to try to do myself with my father in law and few buddies if I have enough beer lol. With the spot that we have layed out for it the grade is on a slight slope and not sure if we should level it out first or just start laying the posts then level after. Any advice would be great I will try to post pics when I get a chance. Thanks
M
mcnair06goat
tn
Thats what i was thinking the concrete guy told to use gravel instead of soil. Because the gravel will pack down and hold better for the concrete later on. But one corner to the other corner is roughly a ft dif in height.
M
mcnair06goat
tn
Im trying to get fill dirt prices but people dont like to answer u back anymore these days.
M
mcnair06goat
tn
Getting quotes is the fun part. Lol my cheapest quote
30x60x12 with steel trusses on 10 ft centers
6x6x16 pt posts
2x4x10 pt bottom girders
2x4x10 girders 3' spacing
2x6x10 purlins 2' spacing
10'6" ridge caps
All metal roof,walls,end walls
36"man door
1" colored screws.
Large corner trim and rat guard are extra
What is there I'm missing that I need to dry this in besides doors I have a panel type insulated 14x10 roll up already. And looking for a 9x9 or so for tractor for the rear of shop.
M
mcnair06goat
tn
Just upgraded to 2x8 bottom girders at no charge. Quote is just under 8k with no tax added yet
Kevin54
MEMBER EMERITUS
Urbana, Ohio
You don't want to backfill with fill dirt. If you try to dump fill dirt in to bring the grade up higher, you'll be asking for trouble later on down the road when the dirt finally settles and your concrete cracks. Backfill with stone and rent a plate tamper and tamp the stone down.
When you backfill with stone, have some dumped in and spread out, wet it down, then run a plate tamper back and forth until it won't tamp anymore. Dump some more gravel in and repeat. You'll be glad you did.
I didn't do it on my garage and even the stone settled. I have control joints and it cracked in the joints like it was supposed to, but even at that, the slab has settled some, maybe a 1/2" overall, but if I walk through the garage and tap the floor with a spud bar, you can hear hollow spots.
One thing no one wants in a garage is cracked floors. Back fill with stone and tamp. You also want to use rebar. It cost a little more, but it will keep and slab from dropping lower than an adjacent portion if the slab cracks where it shouldn't. You'll hear a lot of people telling you that you don't need rebar but to use the concrete wire instead. The wire can stretch. It will let one portion of a slab drop down to an adjacent section. Also don't buy into the fiber reinforced concrete that it keeps a floor from cracking. It doesn't. A floor will crack just the same with it than without it.
Shop around if you have different lumber companies. Use the cost estimates to negotiate for a better price. Remember that Lowes always has the price match plus 10%, or at least they used to.
And make sure you keep us updated with pics. We like pics. The more pics the better. And taking a lot of pics can benefit you on down the line if you ever have to move some wiring, add partition walls, anything that modifies the building, because you can always reference back to the pics.
Good luck and looking forward to hearing your progress and seeing it.!!!
M
mcnair06goat
tn
So u think i need to do the holes and set posts in first along with 2x8 bottom band to hold the rock in after framing. Then do the rock, the worst grade difference is like a foot from front right corner to left rear corner. I will try to get so pics up but it is wet and I need to mark off location a lil better for a more detailed layout.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
At them heights ~8 inches to 13 inches what type of rock should I use?
No.57 crushed stone, compacted after every few inches deep.
Although I have never done it, and I know that people on here have, and I have saw it done on a couple of new houses that were built across from my dads place, they used dampened sand. Not wet, but normally when you dig in a pile it has that amount of moisture, then lightly run a compactor all over it. The reason being is that sand has no voids when dampened and compressed. Just think of the sand sculptures they make on the beaches.
Someone on here that has used sand may want to chime in on that. Like I said, I've only saw it done but have no experience with it. But it does make sense.
NHBandit
East Tennessee
I know you want to buy a kit and build it yourself but have you looked into National Barn Company ? They are in Portland TN and I got what I feel is a smokin deal from them on a 30x40 delivered AND assembled.
M
mcnair06goat
tn
What's a smokin deal. We are at 9k for kit with 1ft overhangs all 4 walls, insulated roof, all lumber, trim, etc. we are building it ourselves but if national has a better quote ill look into them also. We are bouncing between a 30x48 or 30x50 steel truss. Wife keeps talking me down to a smaller shop. :(
NHBandit
East Tennessee
Mine is smaller. 30x40x12. But their price including scissor trusses so I have the height for a lift, 2 10x10 frameouts for overhead doors (I supply the doors), gable vents, walk through door, 1 window, fully insulated, is $11,600. Mine is going to have the 2 overhead doors on the long side rather than on the end of the building. That's with delivery and assembly & TN tax included. I have to provide the slab. Mine is being built on top of the slab because my land has alot of Limestone ledge and digging to put posts in the ground could get expensive. The site work & concrete is going to run me an additional 4k and work is supposed to begin tomorrow if the damn rain would ever stop. I'm sure you can save a bunch of money by doing your own build. I'm going this route because I don't have the equipment or the ability to do it myself. I am doing my own electrical and installing my own lift. I've done a couple of lift installs in the past at a salvage yard I managed and that's a fairly simple job. If you want to know who to talk to or other details feel free to send me a PM on here.
M
mcnair06goat
tn
That's not bad u will definitely have yours started and done by time I get going. Post up pics if u can.
M
mcnair06goat
tn
I found some triplex 2/2/4 service wire is this ok for around 125' on a 100 amp sub for the shop. It's 85-90 feet from the house but I need at 30-40 feet for the vertical runs and under the house. How deep am I suppose to bury this also. Thinking 1 1/2 conduit underground too
M
mcnair06goat
tn
Well I think we're going with a 30x50x12 with steel truss. Found a co in Alabama that cheaper and they deliver too. Hoping to get a auger this weekend and start drilling some holes and getting it all squared up. Then wait on materials
M
mcnair06goat
tn
Going with solar guard on roof it's more expensive but should be ok for the roof insulation for a while. Not sure what we doing for walls yet.
M
mcnair06goat
tn
Well we are ordering the materials Monday and starting on the holes tomorrow. What tips u guys give me on the depth and amount of pad to lay in the holes also. 17 holes should be good day.
PetesPonies
I have put up three pole barns. I have leveled each after the building structure was there. I was out 16" at one end this last time, still liked leveling it after the building is up.
M
mcnair06goat
tn
That's my plan hoping to get building up and dried in then put some gravel base in there. Concrete will be later year or so
PetesPonies
I moved in over 300 Bobcat loads of very sandy ( basically all sand ) soil to even out the 16" situation. This building is 56 X 64, so that's a lot of material to build up a 16" slope. I used wire and fiberglass concrete, with keyways. Its turned out real nice. My second building was out 21", but a bit smaller at 40X 40 to start. That was level mainly with stone, a lot of it. No keyways other than I did the pours in sections. I did get a couple cracks, but nothing that really mattered.
T.Read
Nashville, TN
Who was the company in AL that's helping you out? I found one guy down on the state line that built a 24x24, not a pole barn, for around $10,500 for a guy I know down in Huntsville. Built from the slab up, no insulation or electrical though.
I'm considering getting them to do mine if they'll travel to Nashville. I can only go 700sqft. in my neighborhood. If not, I may try National Barn. That price NHBandit mentioned for a place that big is nice. I reckon my size wouldn't be as bad.
Nice area you got there. What part of Mid TN? I grew up here...Cheatham County, but I live in Nashville now.
M
mcnair06goat
tn
The company I'm talking to and ordering from is Cecil truss co in Alabama. Good group of guys and gal or 2 very helpful and understanding. I'm in lascassas it's in between murfreesboro and Lebanon.
M
mcnair06goat
tn
I'm thinking about using that solar guard insulation on the walls too. It's pricey for the r value but its a start on the wall insulation. I hope it will hold heat in during the winter and keep cooler during the hellish summers around here. Has anybody used the solar guard insulation ?
Pole Barn Guru
Solar Guard is merely reflective insulation with aluminum faces on both sides. If your expectation is to be able to have a climate controlled environment with reflective insulation alone, you are fooling yourself. It is great for condensation control, and to prevent heat gain in the summer. You do have to tape all of the joints, unless you go with the A1V product available from www.buyreflectiveinsulation.com which has a tab with adhesive pull strips on one edge.
Pole Barn Guru
The folks you are buying the building from, should include all of the engineering for depth and size of the concrete piers needed to adequately support the building. If they have not yet - better get on the phone with them. Make sure the information they provide, is sealed by a registered professional engineer, don't just take someone's word for it. This is YOUR new building, you want it to be standing in the same place it starts at, for a long time.
Pole Barn Guru
6x6x16 pt posts
10'6" ridge caps
36"man door
1" colored screws.
If the 6x6 show up and do not have a treatment tag on the end which says UC-4B send them back, as they are not designed to be placed in the ground.
http://www.hansenpolebuildings.com/blog/2012/10/pressure-treated-posts-2/
Pole Barn Guru
6x6x16 pt posts
10'6" ridge caps
36"man door
1" colored screws.
One thing to look into is (assuming the girts are being nailed onto the outside face of the posts), 2x4 wall girts will not work, in fact 2x6 #2 wall girts at 2' on center will not work. It is easy to get a "cheap" price, when there are not enough materials to construct a structurally sound building. One thing I have learned in 33 years of pole buildings - there is always someone who is willing to sacrifice quality, in order to have a lower price.
http://www.hansenpolebuildings.com/blog/2012/03/girts/
domecreek
I envy you folks in the lower 48. You have such a variety of contractors to choose from and the prices are very reasonable. I live in Alberta , Canada, and I certainly wish we could enjoy the selection of companies/contractors and the pole building kits etc., along with the reasonable prices for labour and materials , that you folks in the United States get to enjoy. If I could find these pricing opportunities here in Alberta, I would put up a new pole building in a heartbeat.
M
mcnair06goat
tn
The stick lumber in the original post 2x4s are upgraded to 2x6 grits and purlins with steel trusses
NHBandit
East Tennessee
Exciting to know it's coming together ain't it ? I'm following your thread with interest. I got the call this morning that the materials for my building are being delivered tomorrow. Only problem is East Tennessee is supposed to get nothing but rain, maybe some snow, & damn cold for the next 6-7 days.
M
mcnair06goat
tn
I am also running them on bookshelf grits with blocks if I have enough lumber in kit
