^^^ agreed ^^^
Joe.. the 70 year old worker dude that compacted the sub-grade on my barn said the same thing to me.... as Tony, the young guy, was running the plate compactor. Joe then said "the young guys like the plate compactor 'cause it's easy".
After Tony was done Joe looked at me and said "walk on that".. so I did. Joe then fired up the jumping jack. After about 10 minutes of working one area Joe said "now, walk on that". The sub-grade was remarkably more dense.
Then they brought in the big roller...
Without any further information this could be true, or it could be just the amount of passes.
Cohesive soils, anything with clays, needs shear forces to compact. Soils that stick together will not vibrate down. Two ways to produce shear forces, either an impact rammer such as a jumping jack or a sheeps foot roller.
Granular materials need vibrated to compact most efficiently. The vibration motion allows the particals (with help from water for lubrication) to fall into voids and fill them up. A jumping jack will actually do worse in some gravels.
A vibratory roller is best as it can put more force per square inch but from a good plate compactor its actually just a few more pounds per square inch. A non vibratory roller can actually be worse in gravels and sand than a plate compactor.
What ever you use, depth of lifts is paramount. A lift to thick can cause insufficient compaction even with the biggest and heaviest of rollers. Weight supported at a point is spread out in a pyramid fashion. The deeper you go the less lbs per square inch is there to do the compaction.
A plate compactor is quite sufficient for 3/4 minus stone, gravel, and sand. It may take small lifts under 4" and multiple passes. When I do pads with a bella plate compactor of Number 8 crushed stone it does a job that its difficult to drive a 1/2" rebar grade stake with a 2 pound hammer.
Blindly discounting or recommending any type of compactor without knowing soil types is irresponsible.
Go to the compaction equipment manufactures and ask for the best type of compactor, they will ask what soil/material type. If you ask for one that covers them all they will laugh.
