The floor was just installed & ends at the slider. One of the door has a metal pin at the bottom but because the the steel bottom design it is not tight to the concrete. Should I use some wood/steel to move the pin in closer then drill a hole in the concrete for it? Or should I put a metal plate on the concrete for it to go into? Or do you have another idea?
