tlmartin84
What size do you all typically dig for the pole foundations?
I am comtemplating a couple options.
Pour footings with concrete and insert anchor bolts with a base plate for a 6x6, and go up from that to eliminate wood below ground, shorter post are cheaper as well.
Then there is the standard placing pole in ground and filling around it.
I just don't like the thought of termites and rot, but at the same time I am not sold on the structural stability of the plates on foundations, mainly due to wind concerns.
